ALLIS-CHALMERS 302 baler knives
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: ALLIS-CHALMERS 302 baler knives
    Posted: 10 Aug 2026 at 12:40pm
Has anybody came across a supplier for new cutting knives for the 302 balers...New Holland and other brands that I have looked at don't seem to be the same or interchangeable...seems the 302 has it own unique one.
Matt Folkers
FOLKERS RESTORATION
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 2:00pm
You're talking about the plunger knives, correct? Unfortunately they wouldn't intetchange with any of the common North American balers. There's a chance they might interchange with some from a model of Jones baler because they made the first few models of AC square balers and the later AC square balers still followed the Jones pattern (I'm pretty sure Jones did all of the design and built many of the components for all AC square balers). But parts for a Jones baler would probably be even harder to come by on this side of the Atlantic.
For my 442, I drew them up in CAD and had some burned on the plasma table at work our of AR450 plate, then took care to try and not overheat while grinding the cutting edge sharp. Seems to be doing OK, but I admittedly only do a few hundred bales a year with it. You might try something like that if you can't find a parts unit. I had two cut, because when dealing with olasma/laser table parts, the most of the cost is in the handling and setup. Costs almost the same to do one as it does two or three.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 2:13pm
Yes the cutting knives are what I was referring too...thinking about having mine sharpened at the local welding shop.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 4:50pm
Not that hard to make with a machine shop. Very easy to sharpen. Hardest part is shimming them correctly. HTH Tracy
