Allis C Rear Tires |
rma1998
Topic: Allis C Rear TiresPosted: 10 Aug 2026 at 7:23am |
Can someone tell me if these tires will work on a C. The tires on the tractor has: 12.4-24 on 11" Rim 11-24.
![]() These are the ones I was looking at: http://www.tires-easy.com/12.4-24/petlas-tires/ta60/tirecode/6080 Are they the same size?
Jim.ME
Thanks(1)
Posted: 10 Aug 2026 at 7:35am |
12.4 - 24 is 12.4 - 24. 12.4- 24 is the current size designation for the tire that should be on an 11" wide rim, they just often do not show the wording for 11" rims any more. The ones you are looking at are the same size, just a heavier ply rating.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 93064 |
Thanks(1)
Posted: 10 Aug 2026 at 12:31pm |
yep... most of the tires were 4 ply.. the ones your looking at are 8 ply.. Heavier duty, maybe a little stiffer sidewall... should work great.
rma1998
Posted: 10 Aug 2026 at 1:41pm |
Do you have to use tubes? I assume we'll need tubes. If so which ones?
Jim.ME
Posted: 10 Aug 2026 at 4:30pm |
I get good radial tubes from a tire shop. The shop can give you the right ones. I suspect they will say for 11.2 and 12.4 tires. Radial tubes these days are much better quality in most csaes.
