7000 Clutch issues |
gilduane
Topic: 7000 Clutch issuesPosted: 09 Aug 2026 at 9:08pm |
What am I doing that's not right" When the clutch is pressed the clutch does not disengage, what's wrong " on a Allis 7000 s/n8045
DrAllis
Posted: 09 Aug 2026 at 9:50pm |
Maroon chassis with gear shift on the floor ?? Probably the throw out bearing has failed. There is a cover under the bell housing you can remove to verify.
Kevin in WA
Joined: 08 Feb 2010 Location: Lynden, WA Points: 626 |
Posted: 09 Aug 2026 at 10:19pm |
sn 8045 , I'm guessing its a black belly tractor? If so, its a wet clutch tractor, it could be as simple as a transmission brake adjustment or it could have warped plates in the low range of the 3 speed PS, which serves as your inching clutch.
