170 hydraulic control linkage question |
Toddmac66
Topic: 170 hydraulic control linkage questionPosted: 07 Aug 2026 at 9:05am |
Howdy, I need to see if anyone with a 170 or larger that uses the same design can help me. I have converted my D17 series 4 to 170 fenders. I discovered the pivot pin for the hydraulic levers isn’t long enough.
I just need to know if the 170 uses the same design where it’s a machined surface for the linkages to pivot on and then has threads that pass thru the fender to secure it or is it a long smooth pin on the 170s. I can’t find a pic of the assembly on one and I don’t own that parts manual. If you have one and happen to have a pic of the setup, that would be awesome. I have a feeling I found an unmarked pic of what it could be and it looks like a much longer pin with a support added to it for the inside. Thanks! |
DrAllis
Posted: 07 Aug 2026 at 9:47am |
Same design but at least an inch longer in the threads to go thru the fender brace.
Toddmac66
Posted: 07 Aug 2026 at 10:34am |
Thank you for confirming, I was hoping so but saw that other design and was concerned about that.
