Plowing at MIAPA show 8-2-26
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Topic: Plowing at MIAPA show 8-2-26
    Posted: 03 Aug 2026 at 5:41am
Yesterday we plowed at the Marshalltown show. Conditions were a bit wet but it pulled easier than any other time I’ve plowed there. Here’s the video I shot.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 12:33pm
Mike, thanks for the ride along.  Brings back memories of 70+ years ago.  I never plowed with a slate plow, they came into vogue later.  My Dad had a 4 bottom behind a D 17.  Good to see your TB gauge working.  Looks like you hit some clay for the downshift. It makes sense that
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 4:54am
The clay on the hills gets pretty tough! I like to watch the TB gauge, keep it where it’s active. Blows my mind how well the system works. Guys that designed it 80 odd years ago really had it together!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 8:22am
There are always complainers out there about the Traction Booster system and its performance.  I am and have been convinced that: #1. The system isn't adjusted/configured correctly.  #2. They don't really understand how to efficiently use it.  #3. The tractor still has to be weighted to at least 100 lbs per PTO HP (you can't plow without adequate weight front and rear to compliment the TB).  #4. You need sharp plow shares to keep the plow sucked in the ground so when TBoost tries to transfer it doesn't lift the plow up and out. There are more things that have to be right, but nyou see what I'm getting at. I know if I shut mine OFF on the WD-45, the left land wheel starts to spin depending on the soil conditions.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 6:23pm
Looks and sounds good! Not sure how I missed you at Hutch this year??
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 7:03pm
I really enjoyed the video and appreciate you taking the time to make it. I plowed some as a kid, 200 with a 5/16 semi mount but plowing was headed out in the late 80's. You're unit sure sounds good.
Leon B Mo
Orangeade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangeade Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 8:40pm
Thanks for the video.  Brought back many memories riding on the toolbox with dad 60 some years ago.  No tool box today has the capacity to let me ride now.  Sure miss those days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2026 at 6:13am
I was only there on Friday for about 5 hours, looked but never saw you either.
The plow has basically new shares and I think the new landsides really helped too. I really enjoy moldboard plowing, as you guys have probably noticed. Just try to keep learning and doing a better job. I will say, the slat-bottoms have really grown on me. They work so good when the soil is sticky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2026 at 9:46pm
I didn't get there until 7pm on Friday... so that would probably be why!
