7060 Power Shift
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Power Shift
    Posted: 31 Jul 2026 at 1:13pm
Have spotted one under 4,000 hours. Looks extra good. Had one on the farm that held up well. Has the transmission shown to hold up? Where is the market at on them? What else to watch for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2026 at 10:53pm
The PS transmission overall has been pretty good. You aren't giving the AGE or s/n of the chassis. The PST came out in the Fall of 1975 during the maroon chassis era, and I had my first one apart in the winter of 1976 before the Service Manual was even printed. Seems as tho there was a workmanship problem on this particular tractor that required a tear down to repair it.  Since the beginning there have been several updates and improvements, mostly on external things. How often the transmission oil and filter have been changed has a lot to do with transmission service life. Prior to s/n 4087 they had a quite small filter on the transmission that was (in my opinion) inadequate, as it required changing more often because of its small size.  The same could be said for the transmission suction screen down low that needs to be serviced and monitored when the oil is changed. There was a secondary oil cooler and 8-blade radiator fan that was a required update in those early years. The PST shift valve got multiple improvements too. As time went on, more and more PST's were sold and in the 8000 series I'm pretty sure it sold at a higher percentage to PD transmissions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 6:12am
It is 81 model that the guy tells me he is the secound owner, first owner used it as a planter tractor and now he bales hay with it. Anal about oil changes and upkeep. Has a Sanden update with new tires. After the last fiasco with my last tractor purchase I have learned quite a bit about used tractors and even more about people but I think this tractor stands out. What is a high end price. He himself painted the tractor and it looks great.
Edited by whatscooking - 02 Aug 2026 at 5:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 7:07am
Price is up to you. 1981 is the last batch of them. Tires today are obnoxiously high priced. A/C repairs/updates have happened to all of them now, but shows the owners wanted to keep things up to snuff, versus take off the door and all the cab glass (which sure does happen).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 7:29am
Sounds like a $15,000 tractor in todays market -
Edited by DougG - 01 Aug 2026 at 7:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 7:49am
Firestone radial
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 8:41am
I worked at the AC dealership until June of 1976 when I started my own repair shop. I only remember have two of this series of powershifts apart and these were both after I quit the dealership.
The first one was a 7040 and the bearing adjusting nut that holds the front clutch (A1) drum bearings in adjustment came loose and the drum wollered around and ruined the front part of the transmission housing. If I remember correctly, I think this problem may of been the result of someone working on it before and not getting the nut retained properly. I think they may of damaged the nut lock washer when they tightened the nut to adjust the bearings.
The other one was a 7060 and the bolts  that retained the 75T output gear to the C2 clutch drum worked loose and sheared. I believe this was an early tractor with the smaller (3/8"??) bolts retaining the gear and this was  a known problem as larger bolts were used on the later tractors. The upgraded gear and drum took larger bolts (7/16"??). The parts card indicates that the larger bolts went into production on 7060'S at SN8138. I don't really know if this was a wide spread problem or not.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 11:24am
Those transmissions, for the most part, were dependable. The two problems that Pat described, were the most common of a serious internal failure. Valve body issues were usually the main problem. 14,000-15,000 value???
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 12:43pm
A 7060 will probably never achieve the status of a D21 or even a 220. But like everything else something is only worth what your willing to pay. I myself can argue a 7060 is alot more tractor. Sure is a rabbit hole.
They are asking north of $25,000.00 for it. After I just got done going through a D21 this 7060 see seems like a bargain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2026 at 5:41am
I am at least going to take a look at it. It has the 18.4 42 rears, stadium lighting,but most importantly the owner goes into great detail of how he found the tractor and the extra effort done to correct any problems. Said the injection pump was leaking so sent it to same place he sends all his pumps.
We worked our 7060 hard. Had to fluid the front and put a longer weight bar on to hold the front down using a 11 shank chisel and she never complained. I know they are good tractors.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 6:46am
Way high, can buy a good 8000 series for less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 8:09am
My brother and I looked at 3 or 4  8000's series here in the last few years. Lots of wasted travel miles and standing around at auctions to buy something that had been neglected and maybe abused. Yes. You're right. There are some 8000's that can be bought for the same or maybe less. But, finding that one 8000 that has been cared for and just has good bones will cost you MORE, and probably a lot more. And, we did find a good one a year ago and so far, no regrets. Nice well cared for equipment will generally bring more $$$$$$$$ regardless of the age.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2026 at 8:38pm
How far north? This was 22,500 this spring. Powershift, 7000 hrs.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2026 at 6:13am
I like the 7060 we have but that’s triple what it should bring.  I worked hard to get $30,000 out of a very nice 8050 with basically all new tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2026 at 5:57pm
After asking my brother we didnt fluid the front tires. Was about to and came up with a longer weight bar.
I am planning a road trip.
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2026 at 7:33pm
I have one as my big tractor. 46th black belly 7060 built. Has almost 9k hours.
Powershift sheared the bolts off the clutch pack 2 years ago, and had Mayers rebuild it. Apparently the earlier ones had 3/8 bolts and no loctite on them, later ones had 7/16s bolts and loctite.
Cost me about 12k to have it rebuilt, new air conditioner parts and some oil leaks fixed, and id do it again in a heartbeat
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (1) Thanks(1)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 6:08am
Drove 250 miles to look. When I turned onto his road I could see it from a mile away, orange tractor in front of a old white barn stands out, to me anyway. Pulled up he said you know how to start it check it out. Looked her over pulling dipsticks looking for leaks. Hit the button lights all on correctly started quick lights out,went to the backside of hayfield 3/4 throttle with brake the powershift did it's shifting positively so i used the brake to choke her down to point of killing, i had to do it, no slip. Drove on blacktop for all she had, it liked it.
I parked and and had thoughts of walking away but couldn't. I think he wanted me to have the tractor. It was his baby he bought so his dad could still do some tractor work. Worked on the price, found all the sway blocks and guards, top link, books, great guy.He is going to deliver it the 250 mile distance. I got a armload of Agco filters.
Can ya tell iam stoked. When we finally got a 7060 for our farm new tractor driving went from long hot days to supreme comfort and the horse power to cover some ground.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 8:06am
Congratulations! I enjoy my 7060 too. As you said, "it liked it!" They're the snappiest throttling factory 426 that I've operated.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 1:48pm
I think we're gonna need a pic when you get it home. Congrats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 4:06pm
Edited by whatscooking - 07 Aug 2026 at 4:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 4:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 5:04pm
Thats nice!!!
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 5:18pm
If you had left without that tractor you would have regretted it the res if your life
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
dp7000 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote dp7000 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 5:25pm
Super nice, please post more pictures when you get it home. Really enjoy seeing original low hour tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 6:25pm
I had a learning experience looking at the rear wheels. Ive never seen lugs like that to gi from a 38 cast center to 42 rims
1984 80780
1957 D14
616 tractor
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 7:32pm
So just curious, what's a tractor like that worth these days?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 7:37pm
all I can say is WOW!! that's a show tractor,,really  beautiful  I almost wouldn't want to use it,, jus put it in the house an rub on itWink   yea,, I'm jealous as hell,, that's nice, don't find these every day
ENJOY!..its prolly worth all you paid,, now,, jus take exceptional care of it, like the previous owners..
Edited by Michael V (NM) - 07 Aug 2026 at 7:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2026 at 9:23pm
She's a looker, that's for sure.
