WD or WD45?
Too Tall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Too Tall Quote  Post ReplyReply Direct Link To This Post Topic: WD or WD45?
    Posted: 27 Jul 2026 at 6:02pm
Do I have a Allis Chalmers WD or a Wd45? The serial number is 145148 which puts it between the last number of the 1953 WD 131243 and the first 1953 WD45 146607. My number does not show up on any list that I have found., which seems rather odd.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2026 at 6:34pm
Should be a late '53 WD with a curved shifter and distributor from the factory. Not sure what else may be different that close to the switchover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2026 at 6:36pm
You're reading the chart wrong. Because ( in my opinion), there weren't ever ANY WD's after 146,606.  The first WD tractor in 1953 production was s/n 131,273. The last "WD" was 146,606. Sometime mid-year 1953 the new WD-45 came out at s/n 146,607. It was simply a continuation of the "WD"-series. The last WD-45 in 1953 was s/n 160,385.  So, about 15,000 of each in 1953. I can pretty much say that the first bunch of WD-45's were absolutely the same tractor as the last WD, only with the new W-226 engine and a different air cleaner. I know there are some serial number charts that show otherwise, but this is what I believe to be accurate.
Edited by DrAllis - 27 Jul 2026 at 8:28pm
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2026 at 7:06pm
So yours was close to the end of the WD's. Only 1458 after yours. Smile
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 5:04am
At what point did they change from the pin hitch to the snap coupler? I have two WD's with snap coupler (one is a 1949), but I assume it was changed at some point.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 5:38am
The serial numbers are simply sequential.  Yours falls before 146,607, so it's a WD.
AaronSEIA
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 6:11am
Here are the serial number breaks I have written down;
127,007 constant mesh transmission
136,318 distributor ignition
146,607 first 45, as stated previously
151,381 snap-coupler becomes standard equipment
186,413 4-bolt wide front end
I do not have a number for the first diesel engine tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 6:23am
This site uses a serial number chart that isn't correct and confusing for the WD-series.  Normal s/n info charts use the first tractor s/n for a given year, not the last s/n.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 9:16am
Don't know how accurate....my dad said there were some upset WD owners who bought new tractors very near the end of production when they learned the new 45 had more power and would have waited for it. Sounds like the 45 was a secret till it arrived? Who knows? Makes a good story......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 9:49am
I imagine that happened more than once. But, the WD45 would have been more $$$$ than the last WD was. Wider rear rims and tires and more power would have been nice but not for the same dollars as a WD.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 7:28pm
My grandfather bought a wd 45 and likes the anap coupler so much the dealer retro fitted his wd. Maybe that is the case
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 8:38pm
Likewise, my Dad bought a new WD in 1948 when they came out.  It had a 2-16 mounted pin hitch plow.  It was decided to upgrade to 3-14's snap coupler and a traction booster gauge.  It handled the 3-14's everywhere but alfalfa and then a bottom had to be dropped.
This page was generated in 0.057 seconds.
