190xt turbos ??
Jess View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jess Quote  Post ReplyReply Direct Link To This Post Topic: 190xt turbos ??
    Posted: 27 Jul 2026 at 1:18pm
I have a 190xt that needs a different tubo it's using oil and the intake is full of oil it has a to4b80 on it but I have a parts engine that has a schweitzer I think that is correct on it. My ?? is what turbo is better I also have one with a Garrett rebuilt tag. Should I look for another to4 or Garrett or Schweitzer. There are new options on Ebay for $350 to $450 but not excited about china turbos thanks for any recommendations. I know of a few m2 for parts and L2 but not sure what turbo they have.
Edited by Jess - 27 Jul 2026 at 1:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2026 at 3:15pm
T04-B80 is an Air Research (Garret) and is from a 200 tractor era and are fine.   The Thompson (Rajay) are inferior in my eyes but still work fine. If you change brands you have to use both oil lines as they aren't the same. L2-3 combine might be a 301 engine and you cannot use a 426 turbo. Installing a used turbo, it better be exactly positioned and clocked the same as yours or you will never get it mounted. 50 years of rust and you will twist off bolts and fail.
Edited by DrAllis - 27 Jul 2026 at 3:58pm
