Snap Coupler Disk
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Topic: Snap Coupler Disk
    Posted: 26 Jul 2026 at 7:23pm
I have what I believe is a 7 ft model 20 snap coupler disk. I was told prior owner pulled it with a D-14. I adjusted the hitch height with the screw and have used it successfully on my WD45 with 13 X 28 tires.
Friday I put it on my D-17 (13 x 28) and I seem to have a problem with popping the lift arm snap on one side loose and riding into the opposite tire on turns. Yep, I know "lift it on tight turns" but this was happening on gradual turns as well. The eye is adjusted as far out as possible. Kind of narrowed it down to possible weak spring on latch, chains not the right length, or maybe they had a longer eye setup. Did they have a longer eye or pull bar
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2026 at 8:06pm
Some one can correct me when i am wrong but i think the tongue was shorter if it was for a ca?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2026 at 11:34pm
Your lift arm latches have the mounting set-screw pointed which way ?? They cannot be pointed IN. They must be pointed OUT. A weak spring is very possible. Model 200 ??
Edited by DrAllis - 26 Jul 2026 at 11:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2026 at 6:11am
Set screws are on the outside. Forgot to list that one.
Might be a 200; no model number I can find on it. No upper structure to put down pressure from tongue. Tongue height has a fine thread adjustment screw with the flat stock welded on top to turn it. Will change springs on the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 9:27am
I have seen lift latches that are worn in the lower notch which will allow the pin to ride up and out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2026 at 9:41am
Thank you. I probably won't have it out until next summer, so it may be a while before I see if those changes worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 9:19am
For what it's worth: Found an extra chain/T that I was given some time ago. The "T" that snaps into the latch has a definite inside/outside offset shape that would make it more prone to staying in or more prone to popping out.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 3:45pm
I have a mounted snap coupler disk. The piece only goes into the latch one way, or I'll say that it fit's nicely one way or not so good or not at all the other way.
I'd have ot hoook mine up to know for sure,  but when I hook up the chain it seem spretty obvious that one way is correct and the other is backwards
