7045 problem
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Topic: 7045 problem
    Posted: 23 Jul 2026 at 2:37am
lost pto and hydraulics still have steering and it moves any help is appreciated thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2026 at 5:55am
This might be an easy fix. Under the right lift arm on the 3-point hitch is the PTO valve. On the side of the PTO valve is a tee fitting with a hose connected on the front and a JIC cap plug on the rear. Make yourself a 3000 psi gauge to connect to where this cap plug is. With the engine running you should have 500-600 psi and when you pull back on a remote lever you should get 2500 psi. You probably have zero psi. Swing out the battery tray and locate the compensator control valve on the front of the main hydraulic pump. Check the small spring and shims first. I think you have something wrong there.
Edited by DrAllis - 23 Jul 2026 at 5:59am
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2026 at 7:54am
uploads/963/compen_2026-07-23_07-51-50.pdf
This is a pdf file but this site states it is not a pdf file - so it will not open - grrrr
Item 54-55 are the shims and 56 is the spring to look for
Edited by tbran - 23 Jul 2026 at 7:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2026 at 12:37pm
thank you Dr Allis and Tbran took shims and spring and plunger out couldnt see anything wrong put it back together and everything worked
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2026 at 8:22pm
So, you need some new shims because your pressure isn't in that 500-600 psi range.
