Deteriorating steering wheel
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: Deteriorating steering wheel
    Posted: 21 Jul 2026 at 9:45pm
My original steering wheel on my WD turns my hands black when you use it.
Is there anything a person can use to keep it from
doing so ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 10:29pm
A heavy coat of black paint.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 10:31pm
Thats a good question. The only thing i can think of is a polyurethane paint like they put on wooden tables. You arent the first one ti have this trouble maybe somebody has a better idea
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 10:45pm
i spray paint them with rustolium black satin then i spray them agin and agin them old steeering wheels will soak up a lot of paint but it will make it look shiny and new looking and no more black hands ,  i also fill the cracks with spot putty because it sands easy but it does shrink bad so you have to do more coats  regular bondo workks good also just a litttle harder to hand sand
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 7:14am
I had one of my pulling tractors steering wheel wrapped in black electrical tape (good quality 3M) in a spirol. The whole wheel was covered and no black hands and hides the cracks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 9:20am
Keeping out of the sun helps....
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 11:43am
Some use an epoxy filler then finish it. Here’s a 2-3 min video of it. Note the prep work to clean/widen any existing cracks so epoxy has a better chance to adhere & restore older fatigued areas.
https://m.youtube.com/watch?v=2fkiGXsiSs4&pp=ygUhT2xkIHRyYWN0b3Igc3RlZXJpbmcgd2hlZWwgcmVwYWly
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 3:03pm
Electrical tape might work until you're raking hay on a 100 degree+ day and the glue on the tape starts melting.  Quality paint would be the better option in the long run, why set yourself up for a bigger mess later?
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 4:43pm
Another "not correct" and lazy approach is to simply use a steering wheel cover and lace it onto the wheel.  Works ok unless your wheel is getting extreme use. Can't even imagine the process to remove & replace existing wheel.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 4:53pm
I epoxied mine then used black spray paint.  That wasn't holding up well so I switched to Rustoleum spray on bed liner.  That stuff is holding up really well and I like the resulting appearance.
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 8:42pm
new wheels arnt that expensive for a wd ,  just drill out the pin and pull it off with a puller
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 9:52pm
Wear a tight-fitting pair of goatskin gloves (baling gloves).  If you are baling or cultivating you may need the hand protection anyway! Problem solved.
