Neat option, D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Neat option, D14
    Posted: 21 Jul 2026 at 9:38pm
Went by a fellas place to help him on his D14 and it had this hand clutch kicker on it. I’m sorry, I don’t know the correct name but I do know what it does. Heard about them but I have never seen one before. Pretty cool to see one finally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 10:28pm
After creating the "rock throw-out" for the WD-series, they almost had to retain the same optional feature on the Dynamic new D-series !! The engineer had to really think outside the box with the two-speeds on the same lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 1:32am
Another engineering marvel to resolve a potential dangerous problem. Of all the tractors I’ve seen at shows and on farms I have never seen one mounted on a tractor. Must have been a pretty rare option. There a lot of D series in our area, surprised I’ve never seen one before. Were they an option for all D series snap coupler tractors? Were they factory installed, dealer installed or field installed?
Edited by AC720Man - 22 Jul 2026 at 1:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 5:57am
Rare ? I've got one, from D-14 #1. It's somewhere in the garage, took it off 25 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 6:16am
I've had a bunch of NOS ones still all wired together. They have all sold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 6:26am
1960 Sales book     Catalog number 283729 for the D-17 and 283728 for the D-14.   $13.30 list price      13 lbs       Field/Dealer installed only.
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 6:55am
What's it do? Kick the power director in neutral? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 8:37am
Yes, if you run a moldboard plow it would be good to have one. If he decides to part out the tractor I may try to purchase it since I have 2 SC plows. Engine is locked up tight from sitting outside for many years.
Edited by AC720Man - 22 Jul 2026 at 9:23am
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 9:25am
Interesting, not sure I've seen one on a WD in our area either, I'll have to look around.
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 9:26am
Old Fordsons had a clutch kick-out on the three-points. All three of my Majors have it. They had a heavy 'U' cast bar that you swung up over the top link when hooking up, such that when a rock lifted the plow it would lift the 'U' disengage the clutch. Then had a lever you pulled up to re-engage the clutch and get off it. They also were availabe with custom top links with an internal hydraulic reservoir and hefty die spring, that would disengage the clutch hydraulically via a cylinder on the tractor if equipped. Supposedly a little more responsive. Have one of those top links in a shed somewhere.
In both cases they never saw much use around here. By the time they disengaged the clutch, you were already on top of the rock and had done any damage you were going to do. Most were never used. I suspect that was the same case on the Allis's. I've heard of them several times and know a couple guys who had taken theirs off, but never heard of one being practically used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 10:41am
Does your neighbor want an engine rebuild? I just did another D14 earlier this year.
Edited by PaulB - 22 Jul 2026 at 2:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 1:38pm
I would rebuild it for him but I don’t have the time to do it for months. Too busy at the farm doing my own thing. Do you have one rebuilt now Paul to sell? If so how much? I can see if he is interested.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 1:40pm
I have one my WD45 and it works well. I've had it kick out a couple times.
My family had a similar device on their John Deere's years ago. They worked well. The JD never broke the plow hitting rocks, but they once bent a beam on their Ford hitting a rock. The throwout must have worked.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 1:55pm
As a young lad we had one on a D14. While plowing in 2nd high with 3 14" SC plow you do not think you are going very fast. However if you are standing up looking for a stump you were told was at the fence line and the plow found it before you did  and having the tractor coming to an instant dead stop....  you will not... the kit should have come std with a seat belt. I was lucky to not have broken something and have the spinner knob miss the latisicals.....
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 2:06pm
That happened to me in a D10 and D17. Its a miracke i have children
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 3:29pm
Pretty sure I have a NOS one here. Bought it 20 years ago. Tracy.
