D17 repower? |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5453 |
Topic: D17 repower?Posted: 14 Jul 2026 at 7:17pm |
Has anyone repowered an early D17D with a 5.9 Cummins NA engine? I'd like to find out what issues came up, what someone might do different from what they did. I have someone wanting me to do this for them. I don't see any reason that it can't but if someone else has done it, I don't need to re-invent the wheel.
DrAllis
Posted: 14 Jul 2026 at 8:23pm |
The diesel clutch shaft will be shorter, so that is good. The biggest problem will be the power steering. The PS ram on the right side will (I imagine) not fit because of the width of the RF corner of the engine. I could be wrong, but that area will be a challenge.
PaulB
Posted: 15 Jul 2026 at 10:36am |
For what the use will be the P/S could be deleted. I have very limited experience with tractors larger than a D15. However if I'm correct the early D17s have weaker final drives and that swapping them for 180/185 would hold up better to the torque of the Cummins even as it will not have a turbo. Will this change the overall ratios?
DrAllis
Posted: 15 Jul 2026 at 10:54am |
Series 3 and 4 D-17 final drives are stronger with a ratio of 5.43 to 1 virtually the same as the old finals of 5.45 to 1. 175-180-185's are much wider gears and 5.85 to 1. These drives all use the combination band/disc brake. The S3 and S4 I think have a keyway for the older brake drums while the 175-180-185 do not. The transmission was changed in the S3 and S4 and has stronger teeth in 2nd (plow gear) and 3rd (disc gear) over the early D-17's.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4242 |
Posted: 15 Jul 2026 at 12:31pm |
what is the differance in length compared to a 301? not sure if just rebuiling the oil pan on the steering ram side would be enought if its shorter than a 301 i think it might be doable
DrAllis
Posted: 15 Jul 2026 at 6:51pm |
The G-226 and D-262 engine blocks stopped at the crankshaft centerline. The more modern 2000 series (265/301) engine blocks extend far below the crankshaft centerline for strength, but this unfortunately is where the D-17 engineers placed that hyd steer cylinder. The 5.9 Cummins block would be similar to the 2000 series Allis block.
PaulB
Posted: 15 Jul 2026 at 7:38pm |
What is the length of a 301?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 926 |
Posted: 15 Jul 2026 at 7:51pm |
I know this is out there but thats how my brain works so bear with me. If the cummins had a power sterring pump pump like ive seen on some in trucks and if a 175 front bolster could be grafted into the D17 frame you could change the steering to hydrostatic by grafting a orbitrol on the steering shaft. With the later front axle that the steering cylinder would be on the axle and of course not on the bolster. It would be a heck of a project but with what you want to do you know that already. There are probaly a lot of reasons thatwould not work so feel free to list them
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11980 |
Posted: 15 Jul 2026 at 11:00pm |
Maybe better off with the 4-cylinder Cummins. 4B series; 239 cubic inches. Should help the length issue.
PaulB
Posted: 16 Jul 2026 at 7:48am |
In this incidence P/S is not needed nor is it wanted. I'm looking into what anyone else may have done in the clutch/flywheel area and if they have done this, would they do anything different. The 5.9 6B is going to be used not looking for any other possible engines.
DrAllis
Posted: 16 Jul 2026 at 9:22am |
The bellhousing can handle a 12 inch clutch/pressure plate/flywheel from a 301 tractor engine (180-185-190-200) pretty easily. A little grinding in a couple places but very doable. Stock D-17 clutch was 11 inches.
