D17 series 4 hydraulic valve leak
Toddmac66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Topic: D17 series 4 hydraulic valve leak
    Posted: 09 Jul 2026 at 10:55pm
Howdy, I have been fighting an issue with part of the valve stack on my d17 series 4.   I added the 3rd valve to be able to add a tilt cylinder for the bucket here soon. I had things apart so I added it and capped the ports since I’m not ready to use it.
That valve is constantly pushing oil out of the back of the valve. I have redone all orings on the spool multiple times thinking I nicked it or the orings weren’t correct so I ordered agco rings , same thing happens.
In some research I saw it mentioned it was bad to cap them off and instead they need to be looped, in my mind it’s no different than having a cylinder installed and it not being used but ok…can’t hurt to try and this point so I looped the ports with a hose, same issue.   I haven’t redone orings since I looped it so I suppose slight chance they are an issue but in none of the rebuilds of that spool, have I found an oring that has torn or other visible issue.
On another forum someone mentioned a similar issue and he had a bent screw for the poppet, I haven’t investigated that yet but I wanted to see if there is a D17 s4 hydraulic guru lurking on here that might know what the heck is going on. I tested pressures and they are good. This valve is the same husco part number as the loader valve.
The other loader and rear ram valves work just fine. I’m at a loss here, not super great with hydraulics for one and also not finding many who mess with the D17 s4 design.
I welcome any ideas you all have, sorry for the long post but I wanted to get the back story out there to maybe help someone pin things down.
Thanks!!! Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2026 at 6:22am
On the very end of the spool is the "pressure kick-out" adjustment screw. I imagine you haven't removed it and replaced the small and difficult Oring on that screw. Takes a good quality pocket sized flat blade screwdriver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2026 at 10:37am
I have replaced it a few times and yes, it’s an awful little critter to deal with lol.   Unfortunately I have replaced every seal front to back a few times for the valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 6:16am
I guess I would try something to try and determine where the leak is actually coming from. Place the leaking remote valve in the FLOAT position. Wire that remote lever forward so it cannot move to the rear by itself. Remove the two Allen screws and spacers at the rear and pull off the aluminum cap. Start the engine cautiously and let it run. Have a blow-gun and a can of brake clean handy to dry things off and determine where the leak originates from. I think this would work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 11:55am
I’ll give that a check, I need to finish up some work on the 45 and then the 17 gets to come indoors for brakes and so I’ll try that idea and see If I can learn anything. Thanks!
Edited by Toddmac66 - 11 Jul 2026 at 11:56am
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 11:57am
Ive got a series 4. The three point lever wuold kick off when the lift reached the top but it would pop all the way past hold to down. Of course the poppet screw is froze. I have a spare valve so i took that spool out and put in the tractor thinking they were all the same size between valves. The poppet worked right but the lift leaked down. I said all that to say your valve section may not have the original spool
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 12:43pm
it's been many years since I added that same valve to the stack on my D17s4
One thing that comes to mind, there's a small poppet valve & tiny spting between that and the next valve.  Not sure what it's for, but evidently it's important.
If the extra valve you added in didn't have thiem, that could be the problem.
I think the poppet valve and spring are between each valve….can't recall for sure.
Edited by Gatz in NE - 12 Jul 2026 at 1:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2026 at 1:17pm
Yes sir, they seem to look fine. Two pieces one with a point and then another with a spring around the outside of it that holds against the piece with the finer tip. It’s all part of its detent pressure. The sad thing is this is all pretty simple stuff in terms of parts involved. Just not much to em so I may just be fighting a worn part that I can’t see the wear on and it’s getting past that. I’m gonna try the suggestion above and ensure the fluid is actually coming out of the valve center. Worse case I have one more matching valve I can swap in and hope it’s better condition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 9:34pm
Today I had time to yet again attempt to sort out the leaking valve, wired linkage so it was at float and ran it with the rear cap off the valve, 100% coming out of the center of valve. Tore it down and ran thru Orings and swapped on a different end with spring and screw and the inner components for detent. No difference, she leaks as always.
Being the last valve in the stack, it has the side capped off, is it possible the internal check valve and spring shouldn’t be installed or something dumb along those lines ?
I’m running out of ideas other than once I bring it in the shop to do brakes, I’m gonna at least remove that valve and check it for cracks and ensure torque on the stack is good. I have one more used valve I may swap into place for lack of a better idea.   With it being the only one in the stack that leaks and it’s next to an identical model valve, I’m a bit frustrated with this critter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 9:37pm
It’s possible and although I know better, in all the jacking around and trying things, it’s possible I mixed up the spools and did that. I’m not ruling anything out at this point lol.
This is in response to someone mentioning that valve may not have the original spool inside it.
Edited by Toddmac66 - 21 Jul 2026 at 9:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 9:44pm
Yes between each valve there is what I call a check valve…maybe wrong terminology for it. It is in there but I also wonder if maybe it shouldn’t be since it’s the last valve in the stack, I have no basis for such a thought other than just trying to think thru things ….clearly incorrectly so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 9:52pm
Oil is coming from the center of the spool ??  And you tried a different pressure release adjustment screw with a good Oring on it ??   There must be something wrong with that particular spool inside where the Oring has to seal.  The "load check" poppet in the side of the valve isn't the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 10:31pm
Yes, replaced the orings. I agree, I think I’m dealing with a crack or something I can’t see easily. I did however luck out and just bought an actual Husco 5000 series factory manual on eBay which sure doesn’t hurt my feelings any.   Kinda feel like I hit the lottery lol.
I definitely can’t rule out me accidentally mixing up the spools , I don’t think I did cause I know they are fitted individually but I’ve done dumber stuff so I may swap em just for the heck of it, after that I think it’s time to take it apart when I have it stripped down to pull finals to do brakes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 10:46pm
When I do brakes on any of those tractors with the right side hydraulics, I never remove those valves. I spend a little time disconnecting linkages underneath and wiring them up out of the way. A proper length 2 x 4 jammed between the platform and the underside helps raise things up an inch and the axle comes right out under it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 11:01pm
I don’t think I would either but it feels like now is the time to investigate the valve since I’ll be right there handy. Not too excited about it, the lines and clearance to axle housing and all that involved really sucks to get to. Originally it was just gonna get the fenders removed and swapped out and I was gonna support the valve assembly and leave it be but this leak has altered things. Maybe I’ll get lucky and a spool swap will do the trick and it won’t come to a removal of the whole thing. I really want to retorque the stack and replace that section o ring…again anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddmac66 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 4:56pm
The great saga of the leaking hydraulic valve has finally come to an end I’m happy to say…. Extremely happy to say actually, as this has been a stupid ongoing battle for a while now. I managed to get ahold of a Husco 5000 series manual on eBay and was looking thru it and ran across the diagram for the plunger section and saw it mentioned an oring inside the plunger housing…no part number but it showed there should be one.
I got out the Allis manual and it doesn’t show it at all…..got out my spare valve and took a flash light and sure enough, what looked like all the other grooves was actually a very worn oring.
Pulled the spool out of the tractor today and its oring was worn flat. With the wear on em, they just look like the other grooves until you light it up really well…
Replaced that oring and put her back together and no leak at all now.
Looking at the manual it shows 2 of part number 923376 but in the location drawing , nothing shown as being inside the plunger housing…good times.
I’m too happy about fixing the leak to be mad at myself for not catching that, I always buy multiples of each oring so I didn’t think about why it says 2 qty but never shows where the other one is lol. This is the same oring that runs behind the wiper seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2026 at 5:58pm
That model of Husco valves from 1964 til 1981, (in my opinion) get a 9.5 rating on a 1 to 10 scale. They were quite trouble free, performed faaaar better than any 4010-20 John Deere, had a very nice control feel to them, and on and on. For those of you who have never operated a New Generation Deere with dash mounted hydraulic levers, the A-C system (started with the One-Ninety) was superior for sure.
