Starter
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Starter
    Posted: 28 Jun 2026 at 6:25am
If a starter has a dead spot, will the bendix stay in the flywheel and lock the motor?
How do you test for a dead spot?
This is on a B. 6 volt starter with a 12 volt battery.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2026 at 8:07am
the problem i have had is the bendix it self.... either the throw out screw is gummy or rusted so it sticks... or the spring is broken.... but always a good idea to pull the starter apart, clean up the commutator bars and file the brushes flat again..
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2026 at 10:12am
I will take it apart and check it
'41 Allis B
'49 Farmall Cub
