200 fuel system
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: 200 fuel system
    Posted: 26 Jun 2026 at 10:44am
After I over hauled my 200, motor, had fuel pump and injectors done. It always had a weird sound. Went through and reset valves. It ran ok but always had the feeling something wasn't right. This spring the return line from the injectors was leaking, about a foot from the fuel tank. The line was spliced with a quick slip type connector. I ran a new line from the motor to the tank and now the motor sounds more like a 301 should. All those years it must have leaked enough to let air in until it started leaking more fuel out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:28pm
Those -o - rings have to be good - went thru the same thing ,  luv them 301,s
