13.6 x 28 power adjust rims
amo1977 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Topic: 13.6 x 28 power adjust rims
    Posted: 25 Jun 2026 at 3:02pm
I have a set of like new 4 rail power adjust rear tractor rims with the steel center hubs for a 13.6 x 28 tire. This would fit like a WD 45, D-17, etc. Fairly confident that when in use there wasn't any fluid used. They are like new. Solid around the hole for the stem with no flaking rust. Just very minor discoloration. Would prefer to sell as a set. I got pictures to share. Says file is to big to upload. North Central Nebraska location. $1000 OBO
Edited by amo1977 - 25 Jun 2026 at 3:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 9:58am
What is the rim width from inside of the bead lip to the other bead lip??   10 inches?? 11 inches?? 12 inches??  13 inches??
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 12:25pm
I'm currently away from it till probably Monday. I'm thinking it's 10", but looks a little bit wider. I had another set just like them with tires mounted on them and 13.6 x 28 was the tire size. I'll get back to you when I can get an actual measurement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:41pm
Just measured and 12"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 10:23pm
Those are from/for a WD-45 and will take 13.6 or 14.9 width tires.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2026 at 9:56am
16.9s will also fit on a 12" rim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2026 at 12:00pm
They'll fit on a 10 inch rim too, but it ain't right.
Jgranat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jgranat Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 8:08am
Curious have you sold these rims yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote amo1977 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 9:47am
They're still available
402-340-3182 is s my number if interested
