Swapping drive train on AC Model D
don k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote don k Quote  Post ReplyReply Direct Link To This Post Topic: Swapping drive train on AC Model D
    Posted: 18 Jun 2026 at 11:06am
I have a 1959 AC Model D grader and a at least 1965. The 1965 engine is frozen but everything else looks very good. The 1959 runs and everything works but is getting worn out. Has anyone pulled off the transmission-rear end and tandems in one piece and swapped them to another grader? Looks like it would be fairly simple to unbolt it from the frame and then lift off the frame and replace it with the newer frame.
