wd pto rpm vrs engine rpm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: wd pto rpm vrs engine rpm
    Posted: 13 Jun 2026 at 7:49pm
since the wd was overhauled back in 71  540 has allways been about half throttle    i just put the stewart warner tach on my pto to see where 540 was exactly on the quaudrant and marked it it was where i have run 540 stuff since i was a kid   at full throttle pto rpm is 800  so what is my engine high idle ?     no one is alive that would know what was done but i think it got all 175 stuff in it   its always had alot of power
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 8:13pm
My manual shows the stock loaded RPM is 1400 at the engine and 540 RPM at the PTO. This gives a ratio of about 2.6:1 so at 800 pto RPM the engine will be about 2080.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2026 at 9:28pm
Here are the conversion factors I used for my tachometer application, based on 1400RPM
Edit: Of course that's more precision than actually available on the processor, round as needed.
Also assumes stock tire sizes.
float wdG1CF = 0.00178571428571428571428571428571;  // Ground speed in gear 1 conversion factor (1400)
float wdG2CF = 0.00271428571428571428571428571429;  // Ground speed in gear 2 conversion factor
float wdG3CF = 0.00357142857142857142857142857143;  // Ground speed in gear 3 conversion factor
float wdG4CF = 0.007;  // Ground speed in gear 4 conversion factor
float wdGRCF = 0.00164285714285714285714285714286;  // Ground speed in gear R conversion factor
float wdPCF  = 0.38571428571428571428571428571429;  // PTO RPM conversion factor
float wdBCF  = 0.9;  // Belt RPM conversion factor
Edited by dfwallis - 14 Jun 2026 at 9:52am
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 10:40am
2074 RPM is what I come up with and that is a D-17 governor spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 12:11pm
the guy at the dealership that biult that engine way back in 71 done an awesome job it still runs like new its has just had regular services ,preventive  maintanance and tires the last 20 years it does nt work 50or 60 hrs a week
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 2:09pm
When baling hay or bush hogging with Dad’s WD I always ran close to full throttle, I tried to find that sweet spot where every thing seemed to be working smoothly. I do that with my D15II also since the tach is not working and I am too cheap to buy another one. Again go full throttle and back off just a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 3:21pm
Non-contact laser tachs that used to cost like 3-500 dollars are now available from $10 to $40...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2026 at 4:24pm
Yup!
Calculate to an angstrom, measure with a micrometer, mark it with chalk and cut with a chainsaw... Big smile
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2026 at 5:46am
[QUOTE=DiyDave]Non-contact laser tachs that used to cost like 3-500 dollars are now available from $10 to $40...Wink[/QUOTE Yup, first one I bought only made it through one usage. Just got one last week from hobo freight, haven't used it yet, maybe today?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2026 at 2:09pm
mine runs at 800 rpm full throttle  wouldnt take long for the baler to blow up running that fast  with all of the d17 175 engine parts in that  like doc says 2074  big change fron 1400  i check the mark on the quadrat once in a while if i am working on somthing pto driven  like pumps
