HD5 Driveshaft Parts
Xtremist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xtremist Quote  Post ReplyReply Direct Link To This Post Topic: HD5 Driveshaft Parts
    Posted: 28 May 2026 at 9:30pm
Good evening,
I have an old HD5 that has recently developed a nasty leak at the driveshaft under the floor board. Im not sure if these parts are available in any regard at all but if they are id appreciate any leads... Worst case I could maybe have a machine shop figure something out. I need the following
1x - 056558 - spring assembly
1x - 049109 - boot
1x - 049110 - steel ring
1x - 056598 - bronze ring
1x - 050548 - seal
Any help or insight is greatly appreciated !
Thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2026 at 10:46pm
I have these 2 rings seal,boot,spring assambly and should have the seal yoke
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xtremist Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2026 at 8:57am
sent you a private message
Dobry Den Chip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dobry Den Chip Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 8:34am
try general gear and machine in boise idaho.
