Injectors
Timeline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timeline Quote  Post ReplyReply Direct Link To This Post Topic: Injectors
    Posted: 14 May 2026 at 2:38pm
Greetings. I am looking for a set of injectors for a fiat allis 745B 11000. any help would be great. cores or rebuilt. I am with a new diesel injection pump reman shop. We are Timeline Diesel. We are rebuilding a customer's pump and injectors, but the injectors are in really bad shape and 3 are cracked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2026 at 5:03pm
My mistake meant 715 B TLB on the list I had put up
Edited by Coke-in-MN - 16 May 2026 at 12:04am
Brad in WA View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2026 at 8:41am
A 745B doesn't have a Perkins engine. It has an AC 516 in it, injectors shouldn't be hard to find.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2026 at 2:10pm
11000 engines could have deep cup or shallow cup pistons.
And the injector nozzles are different for each type of piston; make sure the nozzles are exactly the same as what came out. As was told by a HD11-B Guru that the 2 nozzles are not compatible with the different piston from what they were originally with. He found this out the expensive way. . .
tits tyres and tracks
they all cost you money
