belts
allisdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisdozer Quote  Post ReplyReply Direct Link To This Post Topic: belts
    Posted: 12 May 2026 at 5:46am
Does anyone have any tips changing engine fan belts HD16 dozer. Does the hydraulic pump need to be pulled out of the way? Seems like they would engineer it better. But maybe not. Any advise is appreciated. Thanks in advance
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2026 at 12:25pm
Can not say on your tractor, as I have been there on a HD 16. But others I have worked on have double u joint drive. Many times 6 or 8, 3/8 bolts holding a plate inside the front pully. All of that type I have done you can remove drive coupling without moving the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisdozer Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2026 at 12:36pm
this has 6 bolts on crank pulley holding driveshaft on, but no room in the shaft to slide it back and out of the way
