AC 4 bottom 80 series trailer plow
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Topic: AC 4 bottom 80 series trailer plow
    Posted: 09 May 2026 at 8:15am
Allis Chalmers 4 bottom trailer type wheel plow, with hydraulic cylinder included. The 80 series of plows have spring trips. Had all new plow shins, shares and landsides installed with only about 3 to 4 acres plowed since being replaced. The colter hub/bearings were completely rebuilt, the hubs had been bored out to remove worn surfaces and new bushings machined. The spring trip mechanisms will likely need to be cleaned to function properly again.  Also comes with operator’s manual. It just doesn’t get used as much as I thought it would. $1250
I have a forklift to assist in loading onto your trailer.
Add will be removed when it is no longer for sale. Thanks for looking!
Edited by bozrae - 09 May 2026 at 8:20am
D15D, D17G, 170G, 175D, and two 5050FWA
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2026 at 10:04am
I'll take it....
Whats your location in Mi.
Ill send you a PM with my phone number....
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2026 at 10:13am
Located near Dorr Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2026 at 10:24am
PM sent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2026 at 10:53am
Plow is sold
