8550 turbo elbows
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: 8550 turbo elbows
    Posted: 4 hours 18 minutes ago at 8:13am
I need new turbo elbows for my 8550. Old ones have corroded and eroded to paper thin. Part numbers are 70259236 and 70259238. Agco parts books says check with dealer for availability. I'm guessing that probably means my local dealer (butler) does not have them, but could check other dealers. Thought that I would put it on here first in case someone on here has changed them and knows what hoops to jump through to get them. Thanks
Darrel
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 34 minutes ago at 9:57am
Have your dealer call vintage parts 877 846 8243 . Agco moves slow moving items to them from time to time. No dealers show stock.  The turbos were TO4B90's similar to 7060's.  Might use some of the diffusers used elsewhere and modify if you can't locate OEM's.
Edited by tbran - 2 hours 13 minutes ago at 10:18am
