Will combine 2800 work in a 185
ryanschott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Topic: Will combine 2800 work in a 185
    Posted: 20 hours 4 minutes ago at 5:51pm
I got a 185 that sent the rod thru the side of the block have Chance to get an engine out of a combine. Will it work I’ve heard they have longer crank snout. Is that true any other things that would need to be fixed or changed
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 13 minutes ago at 6:42pm
There's a lot of variations in those engines. If it's a 2800 series from an F or early F2 combine, it would come close. Cam or crank driven oil pump is one thing to be considered. Front plate for the hydraulic pump is another.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 38 minutes ago at 7:17pm
What year or serial number is the tractor??? Makes a difference on which oil pan it can have. What year and model of combine is the donor engine coming from ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 15 minutes ago at 7:40pm
1978 185 combine was in junkyard and they drove it in said motors good but combine gone and they don’t remember anything about it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 37 minutes ago at 8:18pm
1978 185 would have the crankshaft driven oil pump with the deep oil pan. Combine engine turbocharged or not ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 2 minutes ago at 9:53pm
The original post mentions a 2800 combine engine. I would assume that it's from an F or early F2,and that it's non turboed. But,who knows. Engines get changed and altered over the years. A 6080 engine or one from a later F2 would make for a sweet project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 19 minutes ago at 8:36am
No turbo. I have the bad 185 motor so if timing cover different can change
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 8 minutes ago at 8:47am
You will have to change the timing cover and the front plate and probably the oil pan. All combine engines have no place for a hydraulic pump, so those parts must come from your tractor engine. This requires pulling the camshaft and replacing it. Also the water pump from the tractor is required.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanschott Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 27 minutes ago at 11:28am
Well new info I just bought a 185 motor for my 185 so should fit. Have to go pick it up in two weeks said it’s out of tractor that ran good but rear end was bad I do have to use my injection pump and hydro pump. Probably the best solution
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 58 minutes ago at 11:57am
'They said' is a pig in a poke, but yes, if it is good runner it will save a couple or three days labor.
