Decellerator pedal for HD4 and 653
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Decellerator pedal for HD4 and 653
    Posted: 07 Mar 2026 at 2:44pm
I will have a batch of the decellerator pedals finished soon. They will fit the HD4 and should fit the 653 and 655. Let me know if you want one. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 7:19pm
They are a MUST on these machines to control the use , instead of trying to use throttle lever and fwd and reverse lever to stop the shock on bull gears and to actually control speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2026 at 7:52pm
Coke, it really does make the machine user friendly! Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2026 at 11:00pm
Had a H4 loader with a 615 detachable backhoe for over 10 years but traded it on a New Holland 785 skid loader , then a FD5 FA Dozer .
 Used the H4 for backfilling foundations and could not imaging running it without decelerator . Being able to creep or stall machine before changing direction without using hand throttle was a MUST .
 Change in work I did made it so HD5G and AC 715 TLB , FD5 worked better doing sewer instillations . Still have the hoe off the machine setting out back as cylinders on it also swap with my 715B machine - but should sell it as not using it much now
