HD 11 |
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 926 |
Topic: HD 11Posted: 02 Mar 2026 at 5:01pm |
Is it possible to buy sprockets for a HD11
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
AC Mel
Posted: 03 Mar 2026 at 10:23am |
Should be able to find some...there are 2 different choices based on serial number.....do you know which one you are looking for?
8070nc
Posted: 03 Mar 2026 at 1:19pm |
No sir. I havent seen it in person yet. The guy that is selling it says the sprockets are still usable but will need changing soon. All this came up all of a sudden. Ive got 55 acres id like to clear to put cows on. Maybe a few acres tilled. Its got some wet spots so ive got to ask soil conservation if i can even do it
1984 80780
AC Mel
Posted: 04 Mar 2026 at 9:37am |
Copy that....well if and when you get some pictures and post them we could tell which sprocket you need.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9234 |
Thanks(1)
Posted: 13 Mar 2026 at 7:42pm |
...if the sprockets are that bad,how do you think the pins and bushings are let alone the rails?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36640 |
Posted: 16 Mar 2026 at 8:50am |
Major Problem is will need to change All or None to make it any viable. Several have gone to locating 955 or D6 Sprocket rings or Segments and then changing out Rollers and that means redrilling frames, Idler can be revamped to accept 6.91 Cat rails where those will then outlive the machine. Are NO 7.0 pitch rails available US any longer.
Codger
Posted: 19 Mar 2026 at 5:39pm |
Don't be discouraging; great fun and exercise to be had rolling track back on that's walked off.
That's All Folks!
Les Kerf
Posted: 19 Mar 2026 at 6:25pm |
Yup. BTDT. Lots of quality family time to be had when that happens!
DMiller
Posted: 19 Mar 2026 at 6:40pm |
Did often on the 7g until swapped rails from that donor.
Codger
Thanks(1)
Posted: 20 Mar 2026 at 4:44am |
I've not had the good fortune to need to do it on anything that small. I remember well a TD-25B tractor doing that track walking bit that down in a pit in December, 1980. Getting it back together to replace track release seals back at the shop was an "ordeal" at best for a 20yo kid working by himself.
That's All Folks!
DMiller
Posted: 20 Mar 2026 at 6:28am |
Worst ever had was a D8 48A, rolled one rail off in a Dirt Recovery company site, as he was trying to roll that back on rolled other side off. Had to roll BOTH back on to get out of the Hole as flood of 1984 was on the way!! Used a Old Track Hoe also in pit for heavy drag work.
Tractor ended up on cribbing for Segments DuoCone seal assemblies, trucks both off and all rollers both idlers resealed both tensioners and replaced both rebound springs, EIGHTEEN DAYS!!!! Bolts broke, had issues with anchor points wear, trucks ended at a weld/machine shop for three days of work.
Poor old machine had been neglected FOREVER, fairly certain were OE Rails. |
Codger
Thanks(1)
Posted: 20 Mar 2026 at 7:26am |
This one had been walked clear of the sprocket at the rear and the pads were pinched between the idler, roller frame, and tractor frame at the front. Several bent pads too. Used my black and white B-61 with the 20k Tulsa winch/sheave block to pull the track free and jacked the tractor on cribbing with a couple hydraulic jacks to get the track actually loose to work with. Then used the winch in different positionionings to drag that heavy SOB into place to roll the track back on. And if that weren't enough, the damned thing fell over on me while winching so needed to roll it back over onto the grouser bars again. I must have been in, and out of that truck 20 times in that hour with all the rigging, pulling, operating etc.
Once finally positioned satisfactorily, machine power pulled it right on. They then drove it to the repair shop but I didn't do anything else myself. Was let go at the end of the month to protect that tenured union operator's employment position though he was known to be rough on equipment and a PBR was part of his lunch break.
That's All Folks!
