fiat allis fl10 |
romain
Topic: fiat allis fl10Posted: 16 Feb 2026 at 5:22pm |
salut les gars moi c'est romain j'ai un fiat allis fl10
Je voudrais savoir si l'un de vous est caler sur ce modèle et ou je peux trouver des pièces et des joints svp merci
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1023 |
Thanks(1)
Posted: 17 Feb 2026 at 1:07pm |
Welcome to the forum!
I'm no expert on the FL10 but I used to own an FL9. Parts are not easy to find but parts like seals and bearings you can research by inner and outer diameter size and with old parts removed you are likely to find letters and numbers on there. Once you have some numbers you can always type them into 'search' and get cross references. Being that the FL10 was likely made in Italy (my FL9 was) you may have some success with a search there, even for used parts. In time, you may get some FL 10 expert on this thread that will come up with the information you're looking for. Cheers
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1020 |
Posted: 17 Feb 2026 at 3:32pm |
We've got a plain FA 10 dozer. The parts book has a table in the back which translates the Fiat bearing part numbers into standard bearing dimensions.
Following discussions on here the parts situation seems a lot better in Australia than in USA. Which means that they are available in Italy if you can make a connection there
ecosse23
Posted: 18 Feb 2026 at 5:19am |
Bonjour d’Écosse,
Je parle francais un petit peu. Si vous cherche sur l’internet, vous devriez pouvoir trouver des concessionnaires de pièces en Italie tels que Tecno Ricambi qui pourraient avoir les pièces dont vous avez besoin - https://www.tecnoricambi.net/en/brands/fiat-allis Vous devriez également pouvoir trouver des pièces de rechange comme des joints et des filtres auprès de fournisseurs tiers plutôt que des pièces d'origine Fiat-Allis OEM (qui seront probablement très difficiles à trouver de nos jours) Il y a quelques informations sur ce forum - https://www.allischalmers.com/forum/fiat-allis-fl10_topic194832.html Hello from Scotland, I speak a little French. If you search online, you should be able to find parts dealers in Italy such as Tecno Ricambi who might have the parts you need - https://www.tecnoricambi.net/en/brands/fiat-allis. You should also be able to find spare parts like gaskets and filters from third-party suppliers rather than original Fiat-Allis OEM parts (which will probably be v. difficult to find nowadays). There is some information on this forum - https://www.allischalmers.com/forum/fiat-allis-fl10_topic194832.html |
