G Creeper again...
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: G Creeper again...
    Posted: 10 Jan 2026 at 9:54am
Someone refresh the memory of how to determine of this has the creeper or how to shift into creeper gear on a G. I had a customer who just purchased one, and I don't want to give bad info.
TIA
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 11:46am
Creeper should be far right and Down on the gearshift.
Should be far right (creeper gear) - center 1st gear - left 2nd gear. All of these are if you press the shift lever down.
Galatians 5:22-24
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 12:22pm
You have to kinda roll your wrist down and right instead of just going right and pushing down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 1:27pm
My understanding is they ALL have it. Some have to be fished into position to get hooked by the shifter.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 1:59pm
Oh Boy! Get out the popcorn! Sorry I couldn't resist. I believe they all have it also.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2026 at 10:30pm
All G's did not have the creeper gear out of about 25 G tractors I've owned over the years think it was 3 of them without the creeper.AC sold a kit to install the creeper in G's so if they had all had them no kit would have been necessary.Back in the 1970's I bought one of those kits from Valley Implement in Harrisonburg VA.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 7:00am
Gary do you know if the ones that didn't have it were early models? I heard once that some of the early ones didn't have it and then they just started putting it in all of them. I have always wondered why they were not all engaged from the factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 7:19am
I don't know,dealers probably just ordered them with the creeper since most buyers got them to cultivate with.In the parts book it shows the spacers where the gears went.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 7:43am
Thanks I have to now believe some did not have it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2026 at 11:14pm
After Gary's first hand expereince,I will conceed that some did not have it.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 5:47am
I did go to the parts book out of curiosity and it shows the spacer and it specifies when the special low gear is not in place! Thanks again to Gary.
