wheel stuck
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: wheel stuck
    Posted: 12 Nov 2010 at 5:16pm
I spent the day getting two wheels and tires retrieved from my "storage depot" ( almost as bad as the dud from Arizona!, not naming names, but his initials are RA! LOL) and changing two rotting wheels on WD. Things came to a screeching halt when it came time to remove wheel from WD. all bolts out, wheel won't budge. BFH around rim, no help. tied chain to wheel over screw jack pushing against axle end. When I couldn't get the screw jack to go any further with regular handle, I applied a wench to jack, broke jack.
I taking my bride out for a burger and beer before I break something else. In the meantime anybody have any ideas? Dave, you wanna come down and muscle this thing off? LOL
I am still confident of this;
Wait for the Lord;
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 5:24pm
You need to get out the heat wrench.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 5:39pm
my friend, if you don't have a fire wrench you may as well surrender now and call the junk man!
LOL, wish I was closer to your side of the state, I'd be over after you got home!
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 6:09pm
We call that the blue wrench
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 6:18pm
I've had to put a hydraulic jack between the tractor and wheel before to force it off, but usually the 12 pound sledge against the tire will bounce it loose after working up a good sweat. I leave two wheel bolts in, turned out about a quarter inch.  Just did 4 of them last week...practice makes perfect. I'm getting pretty good at freeing up the eccentrics also just by using two heavy hammers.  I have one with the wedge shape on one end, it sits against the back side of the pin and up against the wheel center  (wheel still on tractor) so I can give it a good couple of hits, then hit it from the front side, repeat a couple of times with some sprays of PB  Blaster and they will break free unless they are rusted beyond hope.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 7:16pm
 or the gas axe.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 7:58pm
If the tractor is driveable, loosen all the lug bolts about 1/4", drive it, make some sharp turns, rough ground, etc. If rims are rotted and tires are shot, who cares?  You just wanna get the wheel broken loose from hub. Be careful!  FWIW
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 8:16pm
I beat the snot out of one last week. Fun times!
Clay in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay in MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 8:55pm
I've used all the methods mentioned but now use a bottle jack between the rim and the tractor.  This way it's less likely that I damage the tractor or that it damages me.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2010 at 10:45pm
This technique works real well and doesn't hurt a thing. Its actually the least damaging way to remove a stuck wheel.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 4:30am
Instead of a jack,use a hydraulic cyl.
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 6:33am
Use 50/50 mix...ATF & Acetone..soak good..get up in the morning and it'll fall off with above method...(hyd jack)
Edited by JohnThomas - 13 Nov 2010 at 6:33am
Life is short...Make haste to be kind
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 8:36am
I couldn't believe it yesterday I went to take one off a 1956 WD45 at the salvage yard and I was removing the lug bolts then he was going to come lift it up with the forklift so I could get the wheel. As I was removing the last three it started wiggling and the wheel would have fell right off if I wouldn't have stopped. Probably the first time that has happened for me. Must have lived a sheltered life.
somebody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote somebody Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 12:29pm
If you can get some transformer oil from your power co. soak it a couple of hrs.
That is the best pentertrating oil I have found.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 12:45pm
Lou, I was reading the back of a can of loose juice at WallyWorld last night, and if you put two drops on each wheel and block up the tractor before you go to bed, in the morning the wheels will be laying on the ground. That sure must be some wonderful stuff!
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 1:39pm
HEHEHE seems I've heard tha somewhere before!
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 1:46pm
OK, I win! Thanks for all the suggestions and moral support. I tried a bottle jack with the chain around the wheel and pushing against the axle end first because getting the fire wrench to the tractor was going to take more effort. bottle jack worked! While I was at it, I discovered all the bolts holding one bull gear housing on was loose and several missing! Yikes! Guess I was fortunate to have the tire go flat!
Edited by LouSWPA - 13 Nov 2010 at 1:50pm
Wait for the Lord;
This page was generated in 0.184 seconds.
