7060 vibration
hopper88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hopper88 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 vibration
    Posted: 24 Apr 2025 at 11:38am
I have a black belly 7060 with only 4400 hours on it. I have a vibration coming through the floor that comes and goes. very hard to notice but it is there. Its power shift and doesn't matter what gear I'm in. Is more often when under load. Any ideas what this could be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 11:46am
Make a difference leaning left or right ?? I'd suspect 40 year old cab mounts flattened out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hopper88 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 12:34pm
I haven't noticed left or right but I will try different angles and report back. It does do it going down the road as well but that's not says road it straight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 1:04pm
Bad cab mounts can cause all kinds of noises, not necessarily a vibration. More a growling/humming noise that makes one think there's a bearing going out somewhere.
jdeere562 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 2:19pm
Agree withDrAllis on the noise description. Checked one and thought a bearing was going out. Pulled the floor plate to possibly hear better.
Found someone stuffed too long of a bolt in the floor. It was bottoming out on the top of the transmission. Installed shorter bolt and noise went away.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 7:17pm
Put new mounts on a 8070 fwd, huge difference. Thought I had tranny issues also
This page was generated in 0.038 seconds.
