7040 puller torque limiter
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: 7040 puller torque limiter
    Posted: 21 Apr 2025 at 9:36am
I have the engine all buttoned up on my 7040 powershift and ready to do some pulling. From the feedback I have received from just about everyone, It looks like I need to do something with the torque limiter. Seems like most pullers are bolting the limiter solid while a few are using the double belleville washer setup. Has anyone ever actually experienced trans damage from bolting it solid? My 7040 has low hours and is in really nice shape so the last thing I want to do is put the transmission at risk. Does the double belleville washer setup actually allow it to slip or is it a fancy way of making it solid? Is a powershift at more of a risk or less of a risk when bolted solid? I will be splitting it this Friday. I could use some direction. I'm estimating my tractor will have around 300 hp. It will be strictly farm stock. Thanks all.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 11:47am
You should also post this in the Tractor Pulling section.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 12:35pm
You can spend what you want - I - for 300 HP - would double the Belville washer and add a washer under the spools the same thickness of the washer using a 4 disc limiter.  For 400 hp and up? that is a different story - the other clutches are now suspect.  My 2 cents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 1:05pm
Nice low hour tractor you don't want hurt.....and you're going pulling? Those 2 seem diametrically opposed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 4:11pm
SteveM, I'm throwing an awful lot of money at a decent old tractor in an attempt to win just enough money to cover my cold ones and the fuel to do so. The whole thing is driven by my ego and completely asinine. I at least take pride in knowing I am self-aware of my stupidity. Something about it is hard to walk away from. Maybe I am just sick of watching green and reds and all their smiling faces. Not too many orange ones up where I am from pulling anymore, at least that's the argument I gave my wife after she asked for a new couch but got a new built DM4 pump instead. You should have seen how happy she was Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 4:26pm
Suggest you tighten the springs in the couch or otherwise her happiness may could be more expensive than the DM4, or an A or P pump.... her torque will have no limiter...
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 4:40pm
Sounds like the "couch" may be your bed lmao! I put bolts in my flywheel to act as lugs to prevent the disc from ever slipping, but my 7040 is a PD, similar TL though. I used the 8 pad HD one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2025 at 1:11pm
This actually gives me a great idea, Ed. I am decent at machining and metal work. I wonder if I built a large Lovejoy type coupling that would allow the transfer of torque, yet cushioning it at the same time. Sort of like a 175 front pump driveshaft coupling just huge with four polyurethane bushings
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2025 at 3:22pm
The stock heavy duty disc has torsional absorbing springs. I had my machinist buddy make me a pilot tool, then he centered the disc on the flywheel and drilled and tapped the flywheel surface for the 6 allen head bolts. Had to turn the heads down some so they were below the disc surface. The bolts fit nice in the holes in the disc, the HD 6 pad is a full circle with 6 slots, and at the end of each slot is a hole we put the bolts into. They are driving lugs, not bolted anything together. I figure at some point it'll tear the center out on a sled pull lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 7:10am
Your correct Ed. I did not take in account the torsion springs when my revolutionary thinking surfaced.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 10:39am
  Happened on my puller, luckily it tore the center out after I tried to back up right after the pull.
   Lasted ten seasons.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2025 at 5:22pm
Torque damper swap is what ive been going with on our tractors. Did one on the 7095 when I built it and it worked great! Did the 8050 with one from a guy on Facebook that has them made for his cummins conversions. Had the flywheel turned to fit and works great!
Edited by Peterson - 28 Apr 2025 at 6:21pm
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 41 minutes ago at 8:58am
  Is that thicker gauge steel surrounding the springs and attached to the pto hub then stock?
  If so how do I get my greasy hands on it.  PM contact info if you like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 21 minutes ago at 9:18am
It's for a international, but with the power shift hub in it.
https://www.facebook.com/share/1EHJTNfcBg/
This is the guy I got it from. Can do power shift or power director.
