New to me D-17 series 1 hydro issues
Felix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Felix Quote  Post ReplyReply Direct Link To This Post Topic: New to me D-17 series 1 hydro issues
    Posted: 07 Apr 2025 at 3:59pm
What type of hydro fluid do you all use?
Mine appears to have gotten water in it and is grey as a battleship.
Having issues with the pump also. It’s pushing air when I crack the hose at the end. Any suggestions would be much appreciated. TIA
waldersha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldersha Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2025 at 4:06pm
I use the universal hydraulic oil from TSC. I’d probably start with a drain and refill and then figure out if you still have a pump problem but others may have a more informed opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Felix Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2025 at 5:56pm
Thank you
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2025 at 6:03pm
I use a hydraulic fluid that meets 821 specs in all my tractors, simply so I only have to keep one jug in stock. It's a little more expensive, but easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2025 at 7:41pm
From the rear hydraulic fitting? Confused about where you seeing these air bubbles from. I use Fram in a 5 gal bucket from Carquest, 821 approved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2025 at 8:43pm
any "good quality" hydraulic / transmission fluid would be fine.. There should be a list on the bucket of what "SPECS" it meets... If it has no spec, dont buy it.. If it is GOOD OIL it will have 10 - 30 specs listed... CAT, IH, CASE, AC, FORD... etc.
