Hydraulic pump 7000-8000 series
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic pump 7000-8000 series
    Posted: 05 Jul 2024 at 11:23am
Does anyone know who manufactured the hydraulic compensator on the piston n pump for these tractors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 3:31pm
I thought the piston pump was a Cessna, so I assume they built their own compensator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 6:28pm
Thank you, just messing with a tractor with no pto pressure and thinking it could be the compensator. Agco is a grand for a new one and was thinking I could search a little bit and see if I could find one at a jobber maybe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 7:33pm
Well, if the PTO doesn't have pressure, you must have other things not working right either, like poor brakes, diff lock pedal won't stay down, etc. WHAT MODEL ?? Many times the low pressure spool needs a couple of shims to fix them, not a whole compensator. What is your "stand-by pressure ???????
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2024 at 8:08pm
Doc is correct, Cessna supplied the piston pump. I had the low pressure spring break in my 8550, probably 30 plus years ago, the one offered by AGCO was the adjustable type, so updated to it. Good Luck !
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 8:17am
I don't recall ever having to replace a compensator on a 7000-8000 series. Springs can break and shims can also break or just need to be added. The later style, screw adjustable, can break the screws and then the pressure backs off. Sometimes the piston pump itself, is the problem.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 10:02am
 I have a good pump for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 10:26am
Hello, how much for your pump? Where are you located. Just curious, never know when one might be needed
Edited by SilverShoes - 06 Jul 2024 at 10:28am
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2024 at 11:38pm
If you need a pump from one of these tractors rebuilt, I recommend this place. They can rebuild all 3.
https://stoens.com/
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 5:29am
https://stoens.com/
Thanks Creston. I don't need anything from them now, but I sure hope that I can keep that place stored in my memory for future use.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 7:15am
Thank you for the contact
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2024 at 9:39am
  Sent you a PM.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2024 at 9:11pm
Before you dive in too deep, put a load to each of your hydraulic valves. I went through this on the 7045. I had one that lifted slow. The valve had a crack in it.
