7020 Muffler |
CDN 400
Bronze Level Access
Joined: 05 Apr 2014 Location: On. Canada Points: 81 |
Topic: 7020 MufflerPosted: 12 May 2024 at 5:34pm |
Is there any reason the long skinny muffler off a 200 or 7000 won't work on my 7020? I find the oval muffler is in my line of sight for planting so I put a straight pipe on it and I like the improved vision but I find it adds a lot of noise to the inside of the cab which is very quiet with the muffler.
DrAllis
Posted: 12 May 2024 at 5:42pm |
It will work fine.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2548 |
Posted: 12 May 2024 at 5:47pm |
The late 7000s used the oval muffler too.
KJCHRIS
Posted: 12 May 2024 at 6:38pm |
It will fit and work fine.
cowkicker
Posted: 12 May 2024 at 7:21pm |
What size nmuffler clamp does a 7020 use?
DrAllis
Posted: 12 May 2024 at 8:32pm |
3 1/8 inch.
Edited by DrAllis - 12 May 2024 at 9:02pm |
CDN 400
Bronze Level Access
Posted: 12 May 2024 at 9:10pm |
Thanks fellas.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2259 |
Posted: 13 May 2024 at 2:22pm |
I actually made a 3 in exhaust pipe with a resonator installed inside. Also used a couple of angles under the hood to line exhaust pipe up with air breather looks very clean and makes visibility much better. I really don't think it's any louder than it was with the factory muffler on it now but the stack goes just above the roof line.
Leon B Mo |
CDN 400
Bronze Level Access
Posted: 15 May 2024 at 7:50pm |
[QUOTE=Leon B MO]I actually made a 3 in exhaust pipe with a resonator installed inside. Also used a couple of angles under the hood to line exhaust pipe up with air breather looks very clean and makes visibility much better. I really don't think it's any louder than it was with the factory muffler on it now but the stack goes just above the roof line.
I got rid of the air cleaner on hood altogether and made a short adapter and put the original bowl right on top of the air cleaner can under the hood. |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3784 |
Posted: 15 May 2024 at 10:02pm |
CDN 400, if you’ve removed your 7020’s air-cleaner from hood, then maybe consider removing its exhaust straight pipe from hood area too? Could possibly clock (rotate) 301’s exhaust side housing of turbo allowing outlet to exit downward/under right side engine panel? Then route exhaust over & up the right front cab corner? Yes it will require additional fabrication/mounts. But would give a totally open view, if that’s a consideration? If later a straight pipe drone sound becomes annoying at certain engine rpms/loads, then could splice in a 30” long straight-thru glass-pack in the longer stretch where pipe mounts to cab corner. Glass-pack should hush drone without compromising exhaust back-pressure?
CDN 400
Bronze Level Access
Posted: 16 May 2024 at 6:52pm |
