Hydraulics
cwsac.1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulics
    Posted: 10 May 2024 at 5:44am
I got a WD 45 wondering how to bleed the system particularly lift cylinders. Manual gives me a procedure that doesn’t seem to work. Any Intel on bleeding sequins would be greatly appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 6:38am
Stand on the left lift arm. Raise it to the top fully and let the pump hammer its way to relief. Lower lift arms fully. Do this several times. You are bled. Re-check oil level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 6:55am
Yeah, I did what you said everything except for stand on them I put a new packing in so they were emptied if that makes a difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwsac.1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2024 at 6:56am
I was unable to make them leak by the packing nuts
