220 brake parts
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: 220 brake parts
    Posted: 30 Mar 2024 at 10:17pm
Finaly got the left side brake apart today
on the 220 and there's no doubt this tractor
seen a lot of water somehow.
The actuating disc has a lot of rust and some
minor pitting on both sides,so much that replacement might be
in order.
With that being said,are new one available or is there some
place that can weld and turn them down,or just call salvage yard
and hope for decent replacements if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 11:23pm
The actuators and the intermediate disc aren't priced in parts book which means NLA. Says contact dealer for availability so unless you can find NOS a dealer has in the back room you are SOL for new. Probably couldn't afford them anyway. Call salvage. There are probably some better than yours. I'd be surprised if you can weld them but I've been wrong before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 6:38am
Before I'd do anything, I'd be tearing the other side apart first to see what it is like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2024 at 9:01pm
Already did the other side Doc and
it wasn't near as bad.I did one side at a time
so I could look to see how they went back together,
that's just how I do things I reckon,so in this case
I just happened to do the better side first.
Both pedals were stuck but a little lube and they
started moving again.
Maybe the left side wasn't covered as well and got
all the rain and snow IDK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 9:23pm
Finaly got to work on the 220 today
and got the brakes on the left side,
so the brakes are done if I put them back
together the correct way.
Also painted the frame rails except for the
outside of them cause I laid them on the outside,
so will try to get them done this weekend.
Also got the right front axle slid back in.
It was all the way out,not sure why,plowing maybe
but i couldn't get the tie rod broke loose so I
took it off and took to the dealer since I don't have
any heat,call me when it's loose.
Good day I thought...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2024 at 9:25pm
Oh I forgot the right rear tire has
been moved out the end of the axle too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2024 at 8:51pm
Finally did a brake check today on the new brakes,
well as best i could,jacked up the back end and turned
the tires and had daughter pull the pedals,tires stopped
pretty instantly.
I realize it isn't the same as it running on it's own
and trying them but I'm a long ways from that right now.
Just glad they worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2024 at 10:06pm
when they are right they are like power brakes
