another wd to d17 engine cross |
Post Reply ![]() |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3932 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Oct 2023 at 12:47pm |
will wd oil pan work the d17 gas engine
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
They have different part numbers, but the gasket set is the same and the early D17 used the same oil pump as the WD, so I'd think so. AaronSEIA
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22049 |
A D-17 gas oil pan is shaped inward on the right side to accept the starter right tight alongside the pan. A WD pan won't work in a D-17 chassis because of this.
i am going to use the d17 engine with the wd flywheel and bellhousing
1958 tractor
Post Reply ![]() |
