8010 doesn't move
Dave in Oregon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in Oregon Quote  Post ReplyReply Direct Link To This Post Topic: 8010 doesn't move
    Posted: 12 Jun 2023 at 10:23am
I parked the tractor as usual and 5 days later went to use it.  As I pushed the clutch down to start it, it felt different, easier on the top end which was not usual.  Tractor started fine but when I put it into gear, nothing happened.
Have hydraulics- power steering and 3-point work as usual
Took left panel off inside the cab and everything looked as usual
Swung the batteries out of the way (no fuel tank on right side) and blew dirt off the right side of the transmission
Linkage to there looks as though it works as it should
I do have the service and parts manuals
Where do I start?  There are no good AC mechanics in this area.
Thanks for any help and assistance,
Dave
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 11:00am
Power director??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 1:38pm
Oops, forgot, it's a Power Shift
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 1:52pm
I had a problem with steering linkage on one of the 8070s
Had to detach the clutch cable on the firewall to get at it
Forgot to tie the cable back to the bracket. Popped out and did the same thing
Just stopped moving all of a sudden but I rembered and had it fixed in 5 minutes
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
This page was generated in 0.147 seconds.
