ring and pinion-whats it fit?
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: ring and pinion-whats it fit?
    Posted: 29 May 2023 at 12:41pm
In my pile of parts that I acquired from the dealer selling out a few yrs ago, I got this ring and pinion 5117045 and 5117046.  I looked by tractor on agco parts but the number either changed or I didnt come across the right tractor.  Thinkin it was a 185 or 190 or 200.  I thoughtthere was a way to type in part number on APB, but I cant find it.  Googled the number doesn't give me much either.   Thanks, Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 2:31pm
Those numbers are not tractor numbers. Maybe a Super 100 self-propelled combine ??
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 6:50pm
AC Ring gear and pinions come in a set with single pn unless it is for something really OLD- to the best of my knowlege. IF from an old dealer it would have been prior to adding the 70 in front AC always used 6 digit part #/s   As in 70511704-5 - later they dropped the check digit at the end.  as in rotary cutters, manure spreaders and possibly cotton products made at Laporte...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2023 at 6:55pm
180-185-190-190XT 2-pinion differential is 9 tooth pinion gear/shaft and 35 tooth ring gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 1:37pm
This is 9 tooth pinion, 41 tooth ring gear, with 12 mounting holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 1:55pm
If I could see a picture, I might be able to identify. But, as I said earlier, your part numbers given aren't for a tractor.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 7:53pm
So that is 4.56 ratio. What model ran that? I see the WD is 3.5 to 1 and the WD45 is 3.3 to 1 according to the service manual. Smile
