Field cultivator???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Field cultivator???
    Posted: 12 Mar 2023 at 8:21pm
I’d like to get an allis or DA field cultivator. I don’t do a lot of field work so don’t need anything huge. I have an 8050 to pull with but my question is what would be the limit for 200 or 6080. Didn’t want to get something only one horse can pull. Or dumb question, if you had wider one that wings folded up. Can you operate cultivator with it folded or would it damage them. Do I want a 1200,1300 or 1400. I want to get smooth field for hay field.
Thanks
Edited by Mikez - 12 Mar 2023 at 8:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2023 at 8:47pm
Find a 1200 that is less than 20 ft wide and all the tractors will pull it wings down.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2023 at 7:11am
Ideally you want a DMI or even a CIH (the new CIH are red DMI’s) on a limited basis I’ve pulled my 24 foot 4600 with my 6080 on limited occasions with the wings folded up haven’t tried the Tigermate on anything orange yet. Without a crumbler the 24 foot was perfect for the 8030 and 24 foot and a crumbler would be about right for a 8050. Keep in mind trip force of the shanks plays into what you can pull newer cultivators have higher trip force witch is good.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 12:42am
MIKE....Meet your new friend***
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 7:53am
The AC 1200 is a good FC. For other smaller FCs, I’ve also had good results with the similar aged Glencoe FC. It’s 3pt, 12’ wide, 3 rows of shovels, & mounted spring teeth harrow.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 8:44am
If you have any residue, heavy bean stubble, make sure the one you get can handle it.
I have a Will Rich and a 4800 Caseih, both will handle residue pretty well, the harrow will be the problem area. the 4800 has 5 rows of shanks, the Will Rich has 4 rows of shanks.
Both are 24 foot, 8050 handles both easily
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 9:32am
Depends on what you're conditions are, AC field cultivators become a big dump rake when you're dealing with residue and stalks. We had a 20ft 1200 last year, 6080 was working hard to pull it and 8050 played with it.
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 9:47am
My gut says running with the wings up is a bad idea, lotta bouncing around compared to running down a smooth road........??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 9:49am
There is a helluva difference between 2 inch sweeps and 7 inch sweeps as far as residue flowing thru the 6 inch spaced shanks. Also a big diff in how hard they pull.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 10:56am
Meh. . . I did it once when my Allils was down.  Not that bad, they're built pretty tough.  And what is this "smooth road" of which you speak?
johnea4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnea4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 2:25pm
I have a 24' Allis 1200 with folding wings for sale that i used behind a 190xt with no problems.  Like has been mentioned, they plug up quick in trash, but it worked pretty good behind a disk.  Where are you located?  It's in central Indiana and is for sale pretty cheap, needs new hoses for the wing cylinders and new tires on the front depth gage wheels.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2023 at 9:14pm
Thanks guys.
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 1:30pm
So what size shovels is everyone running.
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 1:53pm
I used a maxed out for width 1200 with coil tine levelers behind a 6080 fwa with duals.  I recently used a 25' 1300 without levelers behind my 8030 fwa with duals, both became rakes in heavy trash so I recently upgraded to a 21' 1400 with Willrich spike tooth levelers to clear the trash.  I should mention I made sure the 1400 had the narrower shank spacing option of 7".  Thankfully someone repainted the DA from green to orange.  The 1300
Edited by Michael (WI) - 15 Mar 2023 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2023 at 2:05pm
The 1400
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2023 at 4:42pm
I have two 1400 cultivators and retired my 1300 after pulling it for 42 years. Narrowest 1400 is 24' so may be a one horse only for you but will handle the trash many times better than a 12 or 1300.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2023 at 9:02pm
Oh and I’m in New York
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2023 at 9:36pm
What is dale have in his pictures, 1200
