which tool to remove screw holding latch plate
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: which tool to remove screw holding latch plate
    Posted: 31 Jan 2023 at 2:53pm
went to replace latch plates on arms of rotobaler. It is held in by a machine screw with a big straight head. I can't find a screw driver big enough. I think my grandfather may have had a socket that fit it ? Took the screw to napa today and they had no clue. Anybody got an idea?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 3:08pm
sounds like a draglink socket, check with another local auto parts store, used to be real common
Edited by JoeM(GA) - 31 Jan 2023 at 3:12pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 4:58pm
I made one for a different application from bar stock. Not as handy as a socket but plenty cheap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 5:40pm
Take a piece of a big hex key and sharpen it to fit the screw, at you would do with a worn out screwdriver (hollow grind is best).  then cut the length you need, and insert the hex screwdriver into a hex socket that it fits into...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2023 at 8:24pm
Use a small hammer and punch to drive on end of slot of screw.            MACK
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 6:40am
I have had good luck with an impact tool. A great opportunity to use a hammer.
http://lonsallischalmers.com
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 8:57am
We have always used a hammer and punch to remove/tighten the screw. A nick with a small cold chisel on the screw and the body together will "lock" the screw. They have to be kept tight and can be a real pain if they aren't
regards,
Ken McGregor
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2023 at 1:29pm
snap on has a half inch socket drag link style 5/8 part number sw40E that works almost as well as the piece of strap steel I fabricated a tool from. 62.5 plus tax
