180 power director rebuild.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Topic: 180 power director rebuild.
    Posted: 10 Oct 2010 at 1:50pm
I have not split my tractor yet.
Does anyone have any idea, how much new plates will cost for a power director?
Edited by Clay - 10 Oct 2010 at 1:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 3:16pm
I redone one in a 190 xt series 3 last year , I took the Powerdirector assembly to a dealership and they rebuilt it for $645 including labor- 1.5 hours , new plates, sealing rings and whatever it needed; I took the assembly there cause I am not sure of the tolerances of the clutch hub assembly ; if you need new hubs that gets a little bit xpensive ; ones avaliable from AGCO new at $1600 , and the other side is  NA ;  why make one side new and not the other - go figure - but thats AGCO ; $500 used at a junkyard for the clutch hubs ; there is a place in Germantown Ill.- COOK TRACTOR junkyards that has POWERDIRECTOR clutches put together ready to install for $ 650; its all used stuff - I wouldnt recomend using used clutch plates , but thats cheap for the hub assemblys ;  u will need to replace the trans seal and pto seal while your in there , but thats just a couple seals ; let us know how it goes or if I can help any more  !!!
This page was generated in 0.250 seconds.
