Raddle Chain Shaft Replacement
tractorman21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman21 Quote  Post ReplyReply Direct Link To This Post Topic: Raddle Chain Shaft Replacement
    Posted: 11 Nov 2022 at 6:44pm
    Hello,
          The rear raddle chain shaft on my F2 decided to break right behind where the slip clutch is located and I am wondering on what's the best way to get everything apart.
    I am not sure on how to get to the two gears mounted on the shaft inside that turn the raddle chain. Would you take out the straw walkers and the screens for more access or remove the cleaning shoe and go in that way?
    I only have about 25 acres of beans to go and I am hoping this isn't going to be a major repair.
    Any thoughts or suggestions are greatly appreciated.
    Thanks..
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2022 at 8:21pm
Brake Chain and lay back over walkers. With a good hammer, brake teeth off of old sprockets. Cut old bearings off one side and remove old shaft.
Drive role pin part way on new sprockets (make sure they are in time). Slide new shaft through new sprockets. Reach through and drive pins through new shaft and sprockets . Reassemble with new bearings.                   MACK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2022 at 11:53pm
Tractorman21, did the broken shaft snap around the hole drilled in it that allows roll pin to secure slip clutch housing?
If so, for a mere 25 acre harvest~try tach welding the broken shaft back into position as near plumb as possible using a double washered bolt/locknut placed thru the shaft hole in that the two washer are placed on the outsides(each end) of the broken shaft. With a helper to hold the shaft in position, tighten the bolts lock nut while sandwiching the shaft between the bolt’s flat washer. Spin it to see alignment. Adjust shaft is needed. Tach weld 4 positions as close to outer edges of bolt hole as possible. Between tacks-Spin it, adjust it with hammer, repeat until satisfied. Then when tacks are complete, V grind out material between tacks down as close to bolt hole as possible & layer welds from inside towards outside, being mindful to adjust any Misalignment caused by welding heat/cooling draws/wharps . Don’t forget to wrap a water saturated sock/rag over shaft bearing near welds in an attempt to keep bearing from overheating beyond usefulness?
Smooth & dress shaft to accept slip clutch/drive sprocket,&chain.
If it works, then finish harvest. After harvest do proper repair as Mack suggests.
Edited by AC7060IL - 12 Nov 2022 at 12:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman21 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2022 at 6:53pm
    The shaft did break where the roll pin secures the slip clutch and I did think about welding the shaft back together as a temporary fix. We just had a lot of rain from the storm that hit Florida and it's forecasted to rain again this week. I don't think we'll be able to pick any beans this coming week and I decided to go ahead and try to remove the shaft.
   I removed the straw walkers and the set back plates and was able to get inside and remove one of the roll pins on one the raddle chain sprockets. The left side does not want to come out and I am not sure on how to get it out. I applied a little bit of heat to the sprocket and it still didn't budge. I don't know if it can be drilled out or apply more heat.
   Can I loosen up the raddle chain without breaking it apart to remove the old sprockets and slide out the shaft? I have thought about burning the shaft and sprockets on the inside and replacing everything with new parts.
   How does the shaft monitor on the left side come off? It almost looks like the shaft is threaded and that piece screws off. I don't see a set screw or exactly how that piece is held on the shaft.
   This has definitely been a learning experience and maybe I can get everything replaced before it's time to pick again.
   Thanks for the knowledge and suggestions.
   David
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2022 at 7:56pm
The shaft monitor sensor wheel is a regular lock collar. There is a setscrew somewhere.  Break the chain and wire it so it cannot get away from you. With the chain pulled back away from that nasty sprocket, break off the teeth with a big hammer. Now, torch off the left bearing and pull the shaft out the right side and deal with that nasty sprockets hub in a vise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 6:09am
This is a BIGGER JOB than most realize. That is why I initially recommended the shaft weld. But now you’re into it ,,,,so ahead we steam!!
To loosen rattle chain, go up front, raise feeder/cylinder house throat, & remove rattle chain’s front access panel. There will be old grain/dirt/dust cakes behind panel so be aware. With panel removed, take 2 9/16” wrenches to loosen slack carriage bolts on both sides, using a 2 3/4” wrenches loosen each side’s rattle chain idler pulleys. Rattle chain should now loosen up. Have a helper rotate rattle chain down to front access panel where you can disconnect both rattle connecting links. Yes, you can disconnect rattle connecting links at rear, at side access panels, & at front access panel - BUT ITS EASIEST at front panel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 6:42am
With rattle chain loose & disconnected, follow Mach & DrAllis suggestions to repair/replace rattle drive shaft/drive sprockets/bearings,,,etc.
The original rattle drive shaft snapping at roll pin is a weak area on that shaft. So a bigger QUESTION is WHY did it snap???
1. Rattle slip clutch not lubricated or properly operable?
1. Rattle chain is TOO TIGHT?
2. Too much drive chain tension?
2. Too much drive chain SLACK?
3. Another item driven by that long drive chain STOPPING?? Walkers? Clean grain elevator? Return elevator? Rear beater above walkers?
Rattle chain tension is done at side panels with LIFT TESTs. It should have enough slack that “it can be lifted up by one hand, an inch above side panel’s lower lip.” It’s tension also needs to be EVEN on both side panel lift tests. You adjust its tension up front with its idlers before EVERY SEASON & recheck “side panel lift tests” EACH DAY machine is serviced. A corn cob or any other hard item can lodge into it & create excessive tension that snap an idler “slack carriage bolt” on either side which allows idler to loosen/move & rattle chain EQUAL TENSION is compromised. “Another great Allis-Chalmers Gleaner engineering fact!” A loose rattle chain can continue to operate with none or minimum losses. Rattle chain stays intact, in time, & has enough tension from other idler not to “catch” rattle chain’s false floor & do a “can opener” move!!   So please do your DAILY lift tests.
UNTIL YOU ISOLATE why rattle chain shaft snapped, it may very well happen on NEW shaft quickly. And you’ll be right back to it again.
Edited by AC7060IL - 13 Nov 2022 at 6:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman21 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 4:07pm
   Thanks for all the responses and suggestions. It is definitely a very big project but I do have the time to complete the repairs.
   The shaft broke after the straw walkers jammed up from green grass & weeds. I had originally skipped about a 1/2 acre close to a tree line hoping everything would dry down before I was finished picking on that particular farm. I finished picking all of the fields the night before and came back the next day to try and pick what was left. The combine didn't like the green weeds & grass and I should have just left the field. The straw walkers jammed up and it broke the shaft when everything stopped turning. I am guessing the slip clutch didn't slip and that's part of the problem. I'll look into getting that corrected after I get everything back together.
   I have found the shaft and sprockets at A&I products for a fairly reasonable price? Anyone have any experience using A&I products? Is there a better source for parts?
Thanks again for the help.
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 8:47pm
A&I are not my first choice, but one bought from Agco today may have come from A&I which was made in China.                    MACK
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 9:58pm
You also might have twisted the shaft that runs the shoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2022 at 11:06pm
Unless you dropped the chopper I'd say your flails aren't sharp on the corners and didn't grab the green crap and pull it through. It just beat it back upward and then the walkers plugged. Good way to bend cranks and support plates under walkers. Better check.
