SAE bell housing size pattern |
OldSchoolRecovery
Joined: 06 Nov 2015 Location: Eagle River, WI Points: 301 |
Topic: SAE bell housing size patternPosted: 23 Oct 2022 at 8:52pm |
All,
Does anyone know the SAE pattern bell housing size for the 3500A. ?? #1, #2 or #3 or something different. I have been looking for the last two nights on the innerweb without much luck... Thanks in advance, Carl
1942 Farmall H
1940 Allis B 1944 Allis B 1945 2N 1947 8N 1948 8N 1951 8N 1949 JD M 1951 JD A 1951 JD AW 1951 WD 1952 Allis D Grader 1957 D14 1958 D17 1961 Case 440L 1963 IH Lo Cub< |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1076 |
Posted: 23 Oct 2022 at 9:06pm |
Do you have a housing that you can measure or have an application you are looking for a specific size housing for? There are probably a couple different housings based on what the engine was used in. Generators are usually bigger than truck applications.
OldSchoolRecovery
Posted: 23 Oct 2022 at 9:15pm |
Maybe I am asking the wrong question... What is the bolt pattern on the back of the block? From your answer, I can assume that there are different bells that bolt to the back of the block. And those different bells have different size (SAE pattern). Is that correct?
Thanks, Carl |
1942 Farmall H
OldSchoolRecovery
Posted: 23 Oct 2022 at 10:49pm |
Thanks, I figured it out. Will have to see what I have at that time.
I was thinking the housing was part of the block, not really, but like a part of the block that was the same in all situations. Now I see there are many different sizes. For simplicity sake, I will stick with what is on the engine as It comes with flywheel, ring gear and started that work together. One I can measure, than I will know what SAE # and I can go with that. Thanks, Carl
1942 Farmall H
Codger
Thanks(1)
Posted: 24 Oct 2022 at 5:56am |
I have a chart with the dimensions and mating flywheel sizes on my desktop computer. I'll post it up once finished with harvest tomorrow.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Thanks(1)
Posted: 24 Oct 2022 at 1:10pm |
orangereborn
Posted: 24 Oct 2022 at 3:01pm |
Joe...Thanks for posting that info....Dale |
OldSchoolRecovery
Posted: 24 Oct 2022 at 4:36pm |
I have that chart or page in my folder on my computer. Thanks for posting.
Like I said before, I haven't broken the engine from the alternator yet, but from what I read so-far, on some inner-web forums, they state the MEP 006A gen set is a SAE #1. However, I have a cummins sitting open that is a #1 and the Allis looks a bit smaller. I might be able to get an outside measurement that I may be able to guesstimate for now. I would like the Allis to mate to a GM Turbo 400 transmission. An Allison would probably be a lot easier, but I want no electronics, etc., and I no less than nothing about Allisons, but I can probably rebuilt a 400 in the dark.. Anyway, we proceed, Carl
1942 Farmall H
im4racin
Thanks(1)
Posted: 24 Oct 2022 at 6:10pm |
Go Allison. Look for early 90s school bus with 6bt. Simple cable hook up to inj pump is all it needs.
OldSchoolRecovery
Posted: 24 Oct 2022 at 6:52pm |
Now I am trying to find peak torque for the 3500A ???, which seams like unobtainable information.
The Allison MT-643 has a torque rating of 460. Hp rating of 250, which would be perfect, in my opinion. The innerweb is not like it used to be... Back in the day, you had to try to go down the rabbit hole, Just sayin, Thanks, Carl
Edited by OldSchoolRecovery - 24 Oct 2022 at 6:54pm |
1942 Farmall H
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3580 |
Thanks(1)
Posted: 24 Oct 2022 at 10:48pm |
426 torque question has been discussed before on here. This is a weblink to an older post.
https://allischalmers.com/FORUM/426-670t-engine-torque_topic190850.html |
Gary(WI)
Posted: 25 Oct 2022 at 6:21am |
I have a sae bellhousing flywheel and starter for a 426 if anyone is looking 250 for everything
OldSchoolRecovery
Posted: 26 Oct 2022 at 12:43pm |
I am 95% positive the housing is a SAE #1. Rough measurement and its the same my Cummins, which I did measure as a #1. Will have to wait to break it in half to see what size flywheel it has.
The bell housing # is the rear engine mount and though wide, it will work, especially if I can get the #1 bell to a automatic transmission. I do know that they make #1 to #2 (#3 and #4 also) adapters, but then spacing would have to be addressed. I did leave it outside closest to the shop door, so if I run out of things to do, I can fork it in and work on it, but most likely, and next summer project. Thanks, Carl
1942 Farmall H
kblackav8or
Joined: 05 Nov 2018 Location: Woodland WA Points: 80 |
Posted: 15 Feb 2023 at 10:43pm |
Do you still have that and what you might want for it? |
