3-14 gauge wheel
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: 3-14 gauge wheel
    Posted: 21 Oct 2022 at 9:33am
what rim is available to replace the 4 bolt gauge wheel?, I think it is 4.5 pattern.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2022 at 9:22pm
Bigfish, ag express wheel will be the cheapest most likely. I can measue mine if you have a few days. Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 7:01am
That is a standard 4 bolt AG pattern. You should be able to find something at most any AG bone yard. Many light wagons had 4 bolt hubs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 7:02am
I'm considering cutting the stub off of a scrap C front end and welding that spindle on.
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 2:57pm
any used will still need restored(mine can be blasted and painted), all new i am finding are 5" pattern. wheel vintiques has one for 108.
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 7:40pm
Larry there are usually a couple at the Missouri swap meet . I could grab you one but not until March.
Good to here from you , haven't seen you since Dale's show. Do you know if Richard Aiken is still with us. Haven't seen him post in a long time?
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 9:37pm
I saw Richard at an auction a little over a month ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 9:44am
Good to hear Jordan , thanks for responding
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2022 at 1:11pm
I should have some 4 hole.  Probably both 14 and 15 inch. In your favorite color...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2022 at 4:59pm
i'm going to try a 5" and see if the bearing fit the spindle , a c hub and a wd hub, maybe the bearing will match. thanks for the replies, another 4 1/2 that needs restored doesnt gain me anything. Wheel vintiques has a new wheel for 108. that may fit, but it's not worth that yet.
2014 HD Tri Glide
