WD keeps running when I shut it off
Steve R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Topic: WD keeps running when I shut it off
    Posted: 02 Sep 2022 at 7:35pm
My WD started acting up.  It keeps running after I shut it off.  It doesn't do it every time.  I replaced the switch but it is still doing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 7:37pm
It has an alternator ?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 9:37pm
yes it does
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 9:43pm
Alternator back feeding to the ignition would be my guess but I have no idea how you've wired it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 10:21pm
Your wireing should look something like this.. The KEY shuts off power to the ignition coil... There is a resistor or diode in the signal wire to #1 terminal on the alternator.. That keeps the ALTERNATOR from feeding power to the COIL when you turn the key off... .... Do you have a resistor or diode ?  Somehow #1 terminal is connected directly to the coil... ............ Pull the two prong plug off the alternator, then start tractor, shut it off and see that it will DIE.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2022 at 10:41pm
Runs on sputtering/dieseling or smoothly like ignition switch not turned off or something else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2022 at 8:18am
It starts and runs perfectly then it will shut off just fine 3 or 4 times and then the next time it will keep running.  When it keeps running it runs smoothly as if you never shut it off.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2022 at 9:31am
Does it have really good compression?
Could be possible it’s running like a diesel, on compression....
Just a thought, could be way off though....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2022 at 9:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve R Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2022 at 10:37am
Thank you to all of you for your help, I really appreciate it, and this forum.  I found a short in a wire that I had missed.  Seems to have fixed the problem.  Thanks again.
