D17 Gas Leak |
Post Reply ![]() |
JWingerter ![]() Bronze Level ![]() ![]() Joined: 10 Dec 2015 Location: Kentucky Points: 71 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Aug 2022 at 11:32am |
D17 Series IV (according to serial)
See two images below. My carburetor leaks. Would it be reasonable to expect I might fix this with new gaskets? ![]() ![]() |
D17 Series III
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87632 |
the seat for the INLET VALVE might be cut and causing carb to overflow... YEs, new gaskets, new shut off seat ( or lapping old) , and reset the float level will fix the leak.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21847 |
Your carb is a Marvel Schebler, not a Zenith.
Good catch Dr... I didnt even look at the name on the KIT..
you can get a BASIC kit with gaskets and seals... or you can get a KIT that includes new shafts and valves ......... check if your throttle shaft wobbles in the bore.
It's also NOT a series 4 by the carbs choke linkage.
Post Reply ![]() |
