N5 gleaner
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: N5 gleaner
    Posted: 30 Jul 2022 at 12:14pm
Need to replace belt from clutch shaft to the header pivot...assume start from outside and work inward...support clutch shaft..where will the separation be? Hub inside of hydro drive or clutch pack? Or? Any additional advice from those of you that have been there??? Thanks...Dale
Edited by orangereborn - 30 Jul 2022 at 4:47pm
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2022 at 3:26pm
I have a N-5 ---- never worked on it but it came with some books. been trying to find buyer for the whole unit combine, 6 row 30 corn head, 22? foot bean head and the books for it. last did corn 3 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2022 at 4:11pm
Remove engine belt. Remove hydro belt. Support the clutch shaft with w come-along to the pipe above the clutch shaft. Swing clutch shaft out 3 or 4 inches and swap the belt. It comes apart where that daily grease zerk is located/
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 5:38pm
*********  Thanks...Wanted to make sure...Of course the last person in there put the carriage bolts on the outer bearing support brackert/housing from the inside out.  So that slowed the show a little but decided should do the hydro belt at the same time so have to wait anyway...Dale
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2022 at 8:56am
Brings back memories of my 14 years of working on gleaners.
Couldn't venture to guess how many of those clutch shafts I R&Reed. If I had someone on the outside, I lifted em out by hand, wiggled em just right to get them out the side.
Should check the pocket/pilot bearing while you have the shaft separated. It's supposed to have some oscillation to it, but check it for clicks, or rough spots.
Darrel
