WD45 diesel
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel
    Posted: 29 Jul 2022 at 4:45pm
Can't get my 45 diesel to run at all, sent the pump to two different shops and its definitely been rebuilt and calibrated($2500 basically wasted) and it acts like there is very little compression, took the head off and the casting number is 4506503 which is for a 262, doesn't this head have larger combustion chambers??
I found a different head with a casting number 4506603, is that a WD45 diesel casting number?
A little CQB never hurt anybody.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 5:46pm
That engine can be compression tested. I would have pulled the tractor spinning the engine at higher speeds than a starter to try to get it to run before yanking the head.  Sorry, cannot help you with the casting numbers.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 6:26pm
A). Do you get smoke when cranking?
If the answer is no, then it’s not pumping fuel, the only question is why?
The supply pump is mounted right on the injection pump, and it is possible it’s either not plumbed correctly or it’s not pumping through the filters.
If you DO get smoke, then it’s possible the injection pump is not timed correctly.
More investigation warranted.
And compression can be checked with the proper equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 6:51pm
It's definitely timed correctly, I get TONS of white raw diesel smoke, I did have it running last year for a bit but it runs like crap and pours out white smoke all the time, it not off 180° either.
Injectors pop at 2000 psi.
This isn't my first rodeo, been doing pumps and diesel repairs for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 7:04pm
Your post said " I can't get my WD45 diesel to run at all".  Now, you say you had it running last year. So, did it run like crap last year?? or it runs like crap now ??  It's got the same cylinder head on it from last year, doesn't it ??  Better re-read what you wrote so it can be fully understood. I think those energy cell engines can run 180 out of time, but not run very well. But you knew that because it ain't your first rodeo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 7:19pm
I was using that pretty loosely, sorry.
It ran like crap then and nothings changed.
Yeah it's the same cylinder head, the only one I have.
The guy I bought it from used a half can of ether to get it running, I figured it was just an injection pump issue, it kind of was too.
Timing one is easy as you guys know, #1 on compression, line FP1 mark exactly in the center of the timing hole, position pointer up with the timing mark on pump drive hub.
George at DK diesel in Montevideo MN did the pump work and I trust his work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 7:34pm
One thing to mention, it practically freewheeled when you turned it over with the starter, one piston has a .060"+ gap between it and the sleeve.
And I've never seen sleeves sunk this bad in a block before, it definitely had to be addressed one way or another.
I'll admit it, I got screwed
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 7:51pm
“…Timing one is easy as you guys know, #1 on compression, line FP1 mark exactly in the center of the timing hole, position pointer up with the timing mark on pump drive hub...”
Well, that works perfectly if the timing mark on the drive hub is accurate. I would double check the start of delivery by removing the delivery valve and check for when the fuel flow stops on #1 (going from memory here). You will need a way to pressurize the line to the hydraulic head to get that flow. At the instant flow stops, the FP mark should be in the window.
Just my opinion, of course
(I had to do this method on my Oliver because the timing disc with the mark on it was broken loose from the hub. The early Olivers used the same style pump. The advantage they had was that they had a hand primer pump to pressurize the feed line.)
Edited by TramwayGuy - 29 Jul 2022 at 7:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 7:54pm
one piston has a .060"+ gap between it and the sleeve...... WHAT ??
and you want to know why it runs like CRAP ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 8:29pm
Similar to air timing a Roosa Master, correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2022 at 8:32pm
<span style="color: rgb0, 0, 36; : rgb254, 252, 212;">one piston has a .060"+ gap between it and the sleeve......<b style=""> WHAT ??</span>
<span style="color: rgb0, 0, 36; : rgb254, 252, 212;"><b style="">
</span>
<span style="color: rgb0, 0, 36; : rgb254, 252, 212;"><b style="">and you want to know why it runs like CRAP ?</span>
It won't let me upload the photo of it, but it's hilarious 😆
Whoever put this together, they even put RTV on the energy cell caps
This page was generated in 0.031 seconds.
